Have greddy TT, adding test pipes. Do i need a re-tune?
Old May 21, 2008 | 08:34 PM
sharif@forged's Avatar
Originally Posted by nyqueenz
I also wanna add to this...
I'm doing a greddy TT setup with the Evo TT exhaust.. I also have Helix test pipes which are 2.5" dia... Is this a good for my setup meaning the test pipes it self.. They have no resonators so it’s a st8 pipe..
That would work just fine.
3 inch downpipes are even better, but they are more expensive, and require more installation labor, and the open dumps are LOUD.
Old May 21, 2008 | 09:13 PM
SDGeneralCounsel's Avatar
[QUOTE=App6MT]
Originally Posted by Lawy'dU
it would help since tp and exhaust will cause your car to run more lean. QUOTE]
This would be the main reason you would want a tune. You would make more power by leaning out your tune however you are running the risk of detonation.
hence why you would want a tune lol.
Old May 21, 2008 | 09:17 PM
YellowCelica_GT's Avatar
if my car is running pretty rich, adding the test pipes would lean out my tune a bit right? so would it be safe to run the test pipes without a tune since it will lean out my tune?
Old May 21, 2008 | 09:27 PM
nyqueenz's Avatar
open dump question means.. wastegate opens into the atmosphere not back into the exhast???
Old May 21, 2008 | 10:15 PM
G-Mony's Avatar
how about the opposite....
What if you take off your test pipes? Do you need a tune?
Old May 21, 2008 | 10:59 PM
That's correct. Open dumps vent to the atmosphere, vs. a recirculated setup, that returns the bypass gases back into the downpipe, and out the exhaust system.
Old May 21, 2008 | 11:00 PM
You will richen up, and make less power, but its not unsafe.
So in this case, a retune is not required from a safety standpoint, but recommended, in terms of maximizing your power.
Old May 22, 2008 | 02:04 PM
EricIsKlumzyee's Avatar
^ yeppp just retune man.. like I said before get the most out of your mod.. better MPG, most power, and smoother everything
Old May 28, 2008 | 05:18 PM
ttrank's Avatar
Grocery getter
That's why you route the back into the 3" exhaust at a smooth angle down the line.
Old May 28, 2008 | 09:25 PM
That looks great! We did a set a while back. I just wish we could make them quickly, and for less money.
That's the best of both worlds right there.
Old May 29, 2008 | 02:49 PM
2slo2bfurious's Avatar
lol, looks like a pain to install...
Old May 29, 2008 | 03:47 PM
GreenGoblin's Avatar
The goblin resurrection
o ya that does look good but a pain at the same time
Old May 29, 2008 | 09:54 PM
ttrank's Avatar
Grocery getter
It was.
But well worth it now.
Old May 30, 2008 | 06:44 PM
superchargedg's Avatar
Those look allmost to good to put on the car.
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
mbe32
Nov 13, 2015 11:09 PM
