Bank 1 rich + cyl. #2 misfire = bad tune?
Old Jun 19, 2008 | 06:09 PM
Jtrain's Avatar
Is it a bad tune or just a bad plug / injector ?
Any advice, ideas.. or anyone know the answer lol
Old Jun 19, 2008 | 06:20 PM
G37Rider92649's Avatar
could be......yes...who tuned it?
Old Jun 19, 2008 | 06:58 PM
Jtrain's Avatar
Jack @ japtrix.
1. One step colder or stock - I don't remember what my shop did. Hopefully one step
2. Whatever comes with greddy 440cc right?
3. 41,000 miles.. 11k boosted.
Old Jun 19, 2008 | 08:06 PM
hrrrrrrrrrrrmmmm.....what does your tuner/installer has to say about it?
Old Jun 19, 2008 | 08:09 PM
FI'ed G's Avatar
Have you reset the ECU? Did the error come back?
Old Jun 19, 2008 | 08:39 PM
Jtrain's Avatar
HKS:iS -- I used a scanner and reset the error codes and in 5 miles they haven't come back. My mechanic seemed concerned about the misfire- I always though it was just another day in the F/I drivers life.
I haven't talked to my tuner yet- we'll see what he has to say tomorrow most likely.
Old Jun 19, 2008 | 08:44 PM
escobar929's Avatar
which code did you get? 0300?
thats the code my car is throwing. im hoping its the spark plugs
just ordered new ones, hopefully that will solve the problem
Old Jun 19, 2008 | 09:02 PM
FI'ed G's Avatar
Tell your mechanic that misfire is normal with FI and one step colder plugs. Were do you get the misfire? Misfire under WOT is bad. Did the CEL came up under boost? If you see your CEL come up and blink under WOT then that is bad, if the CEL comes up when just starting the car then that is ok.
Old Jun 19, 2008 | 09:58 PM
2slo2bfurious's Avatar
P300 is normal but P302 is not, there is a chance you have a fouled spark plug or problem with your coils, but I'd say the spark plug if its only happened once.
Bank 1 rich might hint to you having a fouled upstream o2 sensor.
Old Jun 19, 2008 | 10:50 PM
FI'ed G's Avatar
P302 just tell you which cylender which is Cyl 2 so it is no different than P0300. I always get P300 and P302 hand in hand. I only get misfire on cold start up. You are right that it could be the coil pack or sprark plug.
But P0300 could be also:
Faulty oxygen sensor(s)
Faulty fuel injector
Burned exhaust valve
Faulty catalytic converter(s)
Poor compression
Old Jun 20, 2008 | 12:31 AM
Jtrain's Avatar
well i could definitely have faulty 02 sensor, cat and poor compressoin.
I dont know really what a exhaust valve is, and i really really doubt its my injector.
I'm almost sure this is all from it being at idle. I never notice though- im always going WEEEEEEEEEE under WOT
Old Jun 20, 2008 | 10:47 AM
sliderg35's Avatar
P0302 - I get that one all the time. When you get that, you will always read rich on bank one - so don't sweat that part. My P0302 is simply due to a faulty connection in my harness for cylinder #2. Any fault with O2, Exhaust, CAT would not zero in on one cylinder. Check the connections in your harness. My fix is always to reach under the dash and push on the bundle of wires behind my ECU. The fault immediately clears. The last time it happened, I pulled the harness apart and traced the #2 injector wire from the ECU down the line until I found a loose connector. I re-soldered it and thought that was the end of it. It has happened once since (2 months) and I didn't have time to fix it, so I just pushed on the wires again. I'll go back in when I get a chance.
Edit: Misfire is NOT normal with FI. Other than my wire problem with #2, I get no codes at all.
Old Jun 20, 2008 | 11:29 AM
escobar929's Avatar
my SES light was blinking while normal driving not under WOT
