OEM Fuel Rail upgraded WTB..
Old Jul 2, 2008 | 03:36 PM
nyqueenz's Avatar
Where could i buy this set up.
Upgraded OEM fuel rail system..?
http://www.g35turbo.com/Fuel-Upgrade...uel-Rails.html
OEM Fuel Rail upgraded to accept dual feed lines to create a return fuel system for you Nissan 350Z/Infiniti G35
Old Jul 3, 2008 | 03:17 PM
str8dum1's Avatar
the rails will do you no good without the rest of the return system.
AAM or CJM sells a system
Old Jul 3, 2008 | 03:24 PM
GreenGoblin's Avatar
The goblin resurrection
That is what we are doing for mine some 6an fittings welded to the stock rails
Old Jul 3, 2008 | 05:07 PM
FastDontLie's Avatar
...we dont need roads...
And how much is this upgrade going to cost??
Old Jul 3, 2008 | 09:31 PM
str8dum1's Avatar
the rails alone are not that expensive. not sure why you'd go thru the hassle and still use the tiny oem rails?
Old Jul 4, 2008 | 02:02 AM
2slo2bfurious's Avatar
I'd bet money that can flow enough for 500 or more whp room to spare, thats not a reason to not go this route, especially if you can get it done for cheap.
Old Jul 4, 2008 | 06:36 AM
nyqueenz's Avatar
it should cost a lot less then the AAM kit
Old Jul 4, 2008 | 10:12 AM
QuadCam's Avatar
you can buy bare billet rails for the VQ35 from ross machining. the rails aren't the issue. you need some custom parts to bypass the factory regulator.
Old Jul 4, 2008 | 02:35 PM
When you have access to aluminum scrap, have machine shop experience, have others helping, and limit-less resources this seems more fun to me. so far it cost nothing but time.
Old Jul 4, 2008 | 04:42 PM
rpm06g35's Avatar
I can weld these all day. There is a set up in the making. Dannys car will be the test mule for this. Let me know if any of you have any questions.
jsimonk
Dec 22, 2023 03:49 PM
ara777
Aug 15, 2018 04:11 AM
mtlruss
Dec 20, 2015 01:51 PM
usingthejohn
Media Share G35 Sedan V35
Sep 17, 2015 11:37 AM
