Guys i need help(desperate)
Old Sep 7, 2008 | 10:33 AM
superchargedg's Avatar
I screwed up while i was repairing an electrical wire in the main harness that runs across the front of the motor.I was an idiot and didnt disconnect the battery and one end grounded out and now the engine wont start.
It cranks normally but im not getting any power to my HKSII(no red light is on).I checked all the fuses and they check out good....also with the key in the run position the electric fans stay on all the time.
Anybody have any suggestions were else to look.
Old Sep 7, 2008 | 06:39 PM
Canadian's Avatar
Canada, eh?
I wish I could help..but I know veeery little about electronics in these cars...
Old Sep 7, 2008 | 08:30 PM
dev1983's Avatar
could it be that u fried your HKSII?
Old Sep 7, 2008 | 08:37 PM
G37Rider92649's Avatar
+1....I can't think of shiet either
Hope you fix the issue though and update us when you figure it out.
Old Sep 7, 2008 | 08:44 PM
That G Gray's Avatar
gl man..
Old Sep 7, 2008 | 09:05 PM
pj-le's Avatar
yo
did u ever take out the battery i think there should be more fuses near or the side where the battery is .... gl
Old Sep 8, 2008 | 11:28 AM
Audible Mayhem's Avatar
its probably the fuse in the fuse box back behind the battery labeled ECCS and IGN
pull out every fuse and check it.
hopefully its not the ECU.
Old Sep 8, 2008 | 11:32 AM
Hi-TechG35's Avatar
^+1. You willhave to take the plastics from around the battery cover out and the battery itself. The fuse box is black and you must pull the cover up. Good luck with the fix!
Old Sep 8, 2008 | 01:10 PM
urban's Avatar
GL also as I am bad at electrics too.
Old Sep 8, 2008 | 07:05 PM
Its fixed as i used one of my techs multi meters and it was the stinking top right fuse in the box behind the battery.I pulled that fuse on sunday and looking at it i didnt see that it was blown but using the meter it was bad.I replaced fuse and all is fine....im still looking at this stinking fuse and can barely see were it blew.
Thanks for the help.
Mry
Mar 3, 2023 01:03 AM
bTanz
Oct 15, 2015 02:31 PM
Jiggerjuice
Aug 17, 2015 08:41 AM
Decimus141
Aug 13, 2015 08:42 AM
Detailed Image
Aug 10, 2015 02:29 PM
