TT and built motor project
Old Oct 31, 2008 | 05:14 PM
niceguy's Avatar
Thumbs up TT and built motor project
Well guys I thought I'd put up a post for everyone to see the journey I am fixing to take:
IPP built Stage 2 long block with c2 cams
stock intake with 5/8" spacer
SFR tt kit w/ BB 60-1 hifi's
720cc Precision injectors
CJM Stage 2 fuel system
AAM race pump with surge
VB upgrade
Haltech ems with boost controller and (2) o2 sensors, tuned by Hal @ IP
my own custom 3" exhaust
huge trans cooler
That is all I can think of right now. All parts should be arriving in about 10 days or so. I will keep everyone posted on my progress and final tuning results. I am shooting for 600whp or more on pump gas.
Old Nov 2, 2008 | 06:25 PM
niceguy's Avatar
Well I started removing the engine today...... and dayum there are alot of sensors on this car....LOL. Got the front core support off and the manifold and assorted sensors off. Still have to get this one on the back of the drivers side cylinder head, cause it is a pita to get off. Will get the rest of the accessories off tomorrow and the remainder of the sensors.
Where do you guys hook the hoist to on these engines?
Old Nov 2, 2008 | 06:41 PM
Dynasty.Zero's Avatar
Are you doing the install yourself sir?
Old Nov 2, 2008 | 06:53 PM
Jtrain's Avatar
Context cluess
Old Nov 2, 2008 | 07:21 PM
SDGeneralCounsel's Avatar
Give me pictures or GTFO!!!
Old Nov 2, 2008 | 07:40 PM
fbpem1's Avatar
why are you taking the harness off before the motor is pulled? its easy to leave the harness on while pulling the motor trans as one assembly with the cradle thats what i do of course i have a lift to work with which i'm sure you probalby don't have but if you do or if you have the means to do it this way this is the easiest way to do it. disconnect the ECM and the thin white SMJ from behind the glove blox, undo the grommet behind the IPDM, undo the 3 connectors in front of the IPDM then unclip the harness where its clipped into the body for rouing and throw it on top of the intake its done there adn easier to work with outside of the car. Thats the bulk of harness work in the car aside from the 3 body grounds, 2 by on the B1 timing cover and 1 on the B2 head to the body thats just unclips
heres a picture of how i remove every motor out of an infiniti this happens to be on a 05 g35 coupe.
Old Nov 2, 2008 | 07:45 PM
GreenGoblin's Avatar
The goblin resurrection
i did my own greddy kit was a pain in the *** good luck with yours
Old Nov 2, 2008 | 07:49 PM
niceguy's Avatar
Yeah I am doing all the work myself. Didnt realize the harness could stay on the motor....LOL. Oh well, I've got most of it off now.
I dont have a lift, doing this in my garage. The turbo kit should be here this week and the motor is almost done as well. The fuel system is on it's way as well.
It is a huge project, but I'm no stranger to this type stuff, just not on imports. But IMO it cant be too much different. I will say that with the front end off, it is a snap getting to everything.
Old Nov 3, 2008 | 01:02 PM
Jtrain's Avatar
I can safely say that is the worst picture of anything I've ever seen.
My illegitimate 2 year old has taken better picture of him schiting herself.
EDIT: The previous is meant to read exactly how it is typed.. no typos.
Old Nov 3, 2008 | 01:26 PM
fbpem1's Avatar
and it was taken right after pulling a motor out while my hands were still greasy with my phone, sorry for trying to show someone something and be a active member of the forum and i don't live up to your standards. i guess i will think twice before helping out around here agian when all it gets me is ridiculed by members with a lot of posts.
Old Nov 3, 2008 | 02:05 PM
niceguy's Avatar
FWIW, I appreciate the help.
Old Nov 3, 2008 | 02:06 PM
Jtrain's Avatar
I just troll posts... and I'm bored at work.. No hard feelings =) <3
definitely help others! That's what it's all about!
If you want to get ridiculed go over to my350z.com
Old Nov 3, 2008 | 03:15 PM
Canadian's Avatar
Canada, eh?
Good luck man! Post the results afterwards
Old Nov 3, 2008 | 06:15 PM
superchargedg's Avatar
Your built engine can probably make 600rwhp but the 5at auto wont take that much power and torque even with the vb and cooler.
Old Nov 3, 2008 | 07:03 PM
+100000. OP if you want above 450 whp you really need a built transmission. SFR has one that you can just order from them for like 3k, and they may hook you up with the price since you got your tt kit from them.
