Haltech users in here!!!
Old Nov 17, 2008 | 04:15 PM
niceguy's Avatar
Where are you guys mounting the unit at? Sorry if this is the wrong section.
Old Nov 17, 2008 | 05:29 PM
sharif@forged's Avatar
Passenger side lower kick panel...behind the plastic panel there. However, some models have a large control module there. If it doesnt fit, than I usually tuck it under the passenger dashboard. I prefer to place them, in such a way, that the USB connector is readily accessible. Your tuner will thank you.
Old Nov 17, 2008 | 09:33 PM
niceguy's Avatar
Thanks Sharif. I'll check into this....
Old Nov 17, 2008 | 10:51 PM
SnyperZ's Avatar
I have mine in the kick panel as well..and its mounted to the side of the car. I have the USB port facing down and the cord coming out and hiding under the floor mat.
Old Nov 18, 2008 | 12:31 PM
rcdash's Avatar
Here is a tip: tuck that HUGE PNP wiring harness where you want it first. You are limited by the length to the stock ECU connector. There is plenty of slack then to orient the unit either vertically, or if you squeeze it in, horizontally below that. I tried putting the Haltech unit way up top and it fits (so it's completely out of view), but there is no way to hold it up there (without drilling a hole, which would be hard in tight quarters).
Old Nov 18, 2008 | 12:58 PM
GreenGoblin's Avatar
The goblin resurrection
I do not have haltech but I have the fcon and I am making a bracket to hold it firm with in the kickpanel
Old Nov 20, 2008 | 04:14 PM
_jb's Avatar
_jb
Photographer
I have a Haltech, and like Sharif mentioned, I have a brake module in the usual location used to mount EMS boxes. I mounted mine right under the black trim piece under the glove box. I connect to my Haltech a lot, so this is a handy position. Here's a few pix:
I cleaned up the cables and moved the connectors since this picture was taken, but you get the general look of things...
People usually notice it when they open the door, but it doesn't get in the way once they are seated...
Old Nov 20, 2008 | 06:05 PM
I would kiss you if I tuned your car....such easy access to the USB port.
Old Nov 20, 2008 | 07:47 PM
SnyperZ's Avatar
Old Nov 20, 2008 | 09:50 PM
Hal@IP's Avatar
Here is my typical mounting in a G35. The factory panels pop back in nicely and cover everything. I leave the USB cable under the floor mat for easy access if necessary later.
Note- plug the patch harness into the Haltech before mounting this way
Old Nov 20, 2008 | 09:59 PM
niceguy's Avatar
Dont worry Hal.... I'll make sure it is accessable for you. LOL. I do like the mounting spot you got there. I think Sharif was saying that spot, just without pics. LOL
Old Nov 21, 2008 | 12:35 PM
_jb's Avatar
_jb
Photographer
Sandy would kiss you if I tuned your car....such easy access to the USB port.
Fixed...
Hahaha... j/k...
Hope you and Sandy are coming down to The Run in a few weeks... always nice to see you guys... easy on the test drives this year...
Old Nov 21, 2008 | 12:50 PM
_jb's Avatar
_jb
Photographer
I have an ABS control module located right there.
Old Nov 22, 2008 | 01:50 PM
SnyperZ's Avatar
Thats exactly how I have mine.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Picture Share
Feb 4, 2018 12:41 PM
Blue Dream
Dec 5, 2015 10:56 AM
w4kj4k
Oct 2, 2015 07:57 PM
