APS oil drain plug
Old Oct 1, 2009 | 06:13 PM
KPierson's Avatar
Mine stripped out and I ended up putting in a 5/8" allen head bolt. I'm sure it won't take long for the threads to strip again.
Do NOT use any more torque then needed!
Old Oct 1, 2009 | 09:42 PM
BrianlG35C's Avatar
Ohio G Club Member
Originally Posted by silver g
I will find out
Any luck?
Old Oct 1, 2009 | 11:56 PM
rcdash's Avatar
All you APS guys should be using a Fumoto valve. Put it on once and then never have to worry about washers or overtightening or stripping threads, ever...
Old Oct 2, 2009 | 08:27 AM
BrianlG35C's Avatar
Ohio G Club Member
I know Raj...I've got to trim down those stupid fins around the plug first.
Old Oct 17, 2009 | 01:58 PM
BrianlG35C's Avatar
Ohio G Club Member
I will find out
Old Nov 3, 2009 | 09:10 AM
BrianlG35C's Avatar
Ohio G Club Member
I will find out
Old Nov 11, 2009 | 08:35 PM
mtrappo's Avatar
That's a good idea. I see they also make extensions.
Old Nov 15, 2009 | 11:50 AM
silver g's Avatar
Originally Posted by BrianlG35C
My bad guys...I totally forgot to ask. I was just under my car yesterday and still no leaking...Im gonna txt my mechanic now...so sorry!!!!
Old Nov 15, 2009 | 04:47 PM
silver g's Avatar
Ok spoke to my mechanic and he used a Toyota drain plug washer...it has a paper layer on both sides and aluminum in the middle. However, my mechanic made sure even if you buy it at a toyota dealer he said make sure you get the genuine toyota one...some dealers sell aftermarket ones that suck. It should be the 14mm inside diameter washer.
So far it has worked for me and no oil leaks so far.
G35xdriver04
Nov 7, 2015 08:31 PM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
AuAltima3.5
Cooling
Sep 13, 2015 10:46 AM
johnadlertech
Engine - Complete Motors
Sep 6, 2015 12:45 PM
G35CO
Sep 4, 2015 09:27 AM
