Nitrous vs. SC Longevity
Old Dec 30, 2008 | 05:33 PM
coup de grace's Avatar
All things being constant, what can I expect with engine/transmission life if I compare a 75 shot of nitrous vs. a SC system on stock parts? My engine is nearing 80k miles and I'm afraid I won't even get to use my car long enough to enjoy a FI system. But with that said, I'm not happy enough with the power I'm putting down now, so I've been looking into nitrous.
Old Dec 30, 2008 | 05:43 PM
shabarivas's Avatar
are you serious? are you going to be daily driving with the nitrous all the time? lol... depends how much you use, how good of a kit, etc etc.. but in general... nitrous would be a lot more risky than a reliable SC kit...
Old Dec 30, 2008 | 06:08 PM
Haha, yea I plan on keeping 10-15 bottles on me at all times and just hold down the TURBO button.
No but seriously, I understand the SC will give me power on a daily basis and the nitrous only when I want it. Either scenario is fine for me, I'm just looking to make a reasonable jump in power without having to worry about extra reliability issues down the road.
Old Dec 30, 2008 | 06:10 PM
express705's Avatar
a supercharger is very reliable. i had no problem with my car, but then again, i had way less miles.
Old Dec 30, 2008 | 06:45 PM
Deang35c6's Avatar
High torque tends to break things on stock blocks. Compare the torque curve on a car with NO2 and one with a SC.
Old Dec 30, 2008 | 06:52 PM
str8dum1's Avatar
a reasonable shot would be no different trq wise than any TT/ ST setup. They run TT's on the stock block everyday.
you can get a full blown used NO2 setup for $500. That about 4000$ less than a used SC kit by the time you add guages, ems, injectors etc
Just depends on how you drive. Properly installed and tuned, neither is more reliable.
Old Jan 11, 2009 | 12:23 PM
BoostCrzy's Avatar
if you compare power for power.... the Nitrous system will be more efficient due to not having to overcome a parasitic factor in producing the power....the SC will require the engines work to develop the boost needed to make the power....so from a longevity/wear point of view the nitrous will be "softer" on the motor....as it is more efficient.....and the SC will accelerate wear a bit as it is always engaged and being driven....
as stated above...tune is critical.
-Jack
Old Jan 11, 2009 | 12:36 PM
lekker_droom's Avatar
WHAT?! I thought your car was constantly vomitting oil.
Old Jan 11, 2009 | 11:52 PM
sliderg35's Avatar
I just have one thing to say: "Turbo".
Old Jan 12, 2009 | 08:35 AM
XKR's Avatar
XKR
Op
Old Jan 13, 2009 | 09:36 AM
Q45tech's Avatar
A 75 HP jet would create 60 lb/ft at 6,000 rpm and 120 lb/ft at 3,000 rpm and 240 lb/ft at 1500 rpm.............obviously everything depends on the rpm you engage nitrous.
G35VSHNG37
Sep 10, 2015 01:54 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
Jiggerjuice
Aug 31, 2015 11:49 AM
Jiggerjuice
Aug 26, 2015 09:00 AM
belerin
Oct 31, 2003 06:13 AM
