GT Motorsports: GTM Stg1 block, JWT530bb, Fcon VPro ~475rwhp/~500rwtq
on
![Exclamation](https://g35driver.com/forums/images/icons/icon4.gif)
Alex is a long time customer of ours, he decided to bring his car in for some more reliable power. GTM Stage 1 short block went in, with the addition of EMS upgrade (VPro and Knock amp) and a few other goodies, this is one fast spooling, sedan that will definitely surprise a few people on the road. Thank you for your business Alex we hope you enjoy the new found power!
-George
GT Motorsports
Original build: http://my350z.com/forum/shop-builds/...91-octane.html
Current Specs:
JWT 530BB Twin Turbo System
GTM Fuel Return system
Deatchwerk 600cc Injectors
GTM Stage 1 Shortblock
GTM Stage 1 cylinder heads
GTM Stage 2 turbo cams, 272s
Walboro 255lph pump
Defi Boost & EGT Gauges
GTM/Exedy Stg 1 Organic Clutch/Flywheel kit
GTM Dyno Tuning w/ HKS Knock Amp
GTM Custom Test pipes w/ Flex section
GTM ECU Flash
GTM 56mm Radiator
GTM 14" Fan kit with shroud
GReddy Oil Cooler
GReddy Oil Catch Can
HKS FCon VPro
HKS A/F Knock amp
HKS Camp2
HKS EVC6
Comparison of stock block vs. stock block with Utec vs. built engine with FCon:
![](http://i313.photobucket.com/albums/ll383/GTMPOWER/ALEX%20LEE/STOCK-VS-UTECK-VS-F-CON--ST.jpg)
![](http://i313.photobucket.com/albums/ll383/GTMPOWER/ALEX%20LEE/GTM-ENG-JWT-12-PSI--91-OCT--ST.jpg)
![](http://i313.photobucket.com/albums/ll383/GTMPOWER/ALEX%20LEE/GTM-ENG-JWT-14-PSI--91-100-MIX--STY.jpg)
![](http://i313.photobucket.com/albums/ll383/GTMPOWER/ALEX%20LEE/P1020275.jpg)
![](http://i313.photobucket.com/albums/ll383/GTMPOWER/ALEX%20LEE/P1020285.jpg)
![](http://i313.photobucket.com/albums/ll383/GTMPOWER/ALEX%20LEE/P1020286.jpg)
![](http://i313.photobucket.com/albums/ll383/GTMPOWER/ALEX%20LEE/P1020290.jpg)
![](http://i313.photobucket.com/albums/ll383/GTMPOWER/ALEX%20LEE/P1020291.jpg)
![](http://i313.photobucket.com/albums/ll383/GTMPOWER/ALEX%20LEE/P1020292.jpg)
![](http://i313.photobucket.com/albums/ll383/GTMPOWER/ALEX%20LEE/P1020293.jpg)
![](http://i313.photobucket.com/albums/ll383/GTMPOWER/ALEX%20LEE/P1020294.jpg)
![](http://i313.photobucket.com/albums/ll383/GTMPOWER/ALEX%20LEE/P1020295.jpg)
![](http://i313.photobucket.com/albums/ll383/GTMPOWER/ALEX%20LEE/P1020296.jpg)
![](http://i313.photobucket.com/albums/ll383/GTMPOWER/ALEX%20LEE/P1050222.jpg)
![](http://i313.photobucket.com/albums/ll383/GTMPOWER/ALEX%20LEE/P1050223.jpg)
![](http://i313.photobucket.com/albums/ll383/GTMPOWER/ALEX%20LEE/P1050224.jpg)
![](http://i313.photobucket.com/albums/ll383/GTMPOWER/ALEX%20LEE/P1050750.jpg)
![](http://i313.photobucket.com/albums/ll383/GTMPOWER/ALEX%20LEE/P1050751.jpg)
![](http://i313.photobucket.com/albums/ll383/GTMPOWER/ALEX%20LEE/P1050752.jpg)
![](http://i313.photobucket.com/albums/ll383/GTMPOWER/ALEX%20LEE/P1050753.jpg)
![](http://i313.photobucket.com/albums/ll383/GTMPOWER/ALEX%20LEE/P1050755.jpg)
![](http://i313.photobucket.com/albums/ll383/GTMPOWER/ALEX%20LEE/P1050758.jpg)
![](http://i313.photobucket.com/albums/ll383/GTMPOWER/ALEX%20LEE/P1050759.jpg)
![](http://i313.photobucket.com/albums/ll383/GTMPOWER/ALEX%20LEE/P1050761.jpg)
![](http://i313.photobucket.com/albums/ll383/GTMPOWER/ALEX%20LEE/P1050763.jpg)
-George
GT Motorsports
Current Specs:
Walboro 255lph pump
GTM ECU Flash
GTM 56mm Radiator
GReddy Oil Cooler
HKS FCon VPro
HKS A/F Knock amp
HKS Camp2
HKS EVC6
on
on
![Smilie](https://g35driver.com/forums/images/smilies/smile.gif)
-George
GT Motorsports
on
I've had the car back for a few months now and its running perfectly fine. The power is exceptional and the turbos spool ridiculously fast with no lag whatsoever, which was the main reason I decided to stick with 530bb turbos. The 272 cams really help out the top end power, glad I decided to go with those over the 256s. Difference between Utec and Fcon is night and day! The car is so much smoother and it defintely got rid of the little "jerK" that utec caused when it switched from closed to open loop. The clutch is holding up fine right now, but I'm sure it will need to be replaced within the year. I'm going to recommend potential Gs/Zs going FI to overbuy your clutch!
I'll be back at GTM this year for a few more goodies (SPAL fan speed control unit, os giken lsd to replace quaife, and a few more things
Btw, this is what the car looks like now courtesy of MarcusCookePhotography.
![](http://farm4.static.flickr.com/3265/3103532633_3902aca9d2_o.jpg)
More pics here:
https://g35driver.com/forums/picture...otography.html
More pics here:
wow.... that is nice build. what compression are you running and how many lbs of boost?
I have a built motor with 11:1 compression.... just got it tuned by PF supercars. I did a base run on 9 lbs and he maxed out my aps 500CC injectors.... 450whp and 400 ft lb TQ at 9lbs... i need to hurry up and get bigger injectos so i can raise the boost and see what other numbers i can get.
