upgrading to the 2.87 serp pulley.
Old Jan 26, 2009 | 06:42 PM
ska12's Avatar
Hey i have a vortech g with all stock pulleys and im puttin out 340rwhp. If i wanted to go with the 2.87 pulley which supposivley gives you 30 rwhp would i need new injectors if im only putting down 370whp. I plan to get the utec and the hks hi pwr exhaust also but do not want to get injectors if not necessary?
Old Jan 26, 2009 | 08:04 PM
Mr_pharmD's Avatar
im assuming u are running the fmu right now so u can always change the disc out and u should at least upgrade to a 255 walbro fuel pump.
Old Jan 27, 2009 | 02:26 AM
ska12's Avatar
Well i Bought the car as is so im not sure whats in it. How do i know if i am running the fmu and how do u change out the disk?
Old Jan 27, 2009 | 09:45 AM
ska12's Avatar
also are the bigger injectors (440's) (550's) deffinetly necessary if i get the walbro?
Old Jan 27, 2009 | 09:58 AM
ska12's Avatar
,.,f
Old Jan 27, 2009 | 11:07 AM
GreenGoblin's Avatar
The goblin resurrection
I would go with some 440 injector and a walbro
Old Jan 27, 2009 | 11:08 AM
shameless plug I have some brand new rc 440's I will let go cheap
Old Jan 27, 2009 | 01:07 PM
Deang35c6's Avatar
Bigger injectors are a must. I have the 2.87 and 800 cc with Walbro 255 and see 11.5 afr on 91 octane across the curve at 11 psi.
Old Jan 27, 2009 | 02:05 PM
Dan_K's Avatar
Yes, 440cc injectors and a Walboro. If you do this, you could get rid of the aux. FMU all together.
Old Jan 28, 2009 | 12:22 PM
Hexxum001's Avatar
With the 2.87 not only will you need bigger injectors and fuel pump (recommended), you will also need to get your car tuned unless you want your engine to go BOOM!!
Old Jan 28, 2009 | 12:46 PM
Dan_K's Avatar
lol, I was assuming (and hoping) he already knew that.
Old Jan 28, 2009 | 01:08 PM
Hexxum001's Avatar
Well, he was asking about going with the 2.87 without upgrading his injectors () so I was assuming that he didn't know.
Old Jan 28, 2009 | 09:12 PM
ska12's Avatar
I knew you had to get the car tuned if u upgraded the pulley. But i read somewhere that you didnt need bigger injectors if you werent above 400whp and i figured i would be around 380, but i figure the injectors are def necessary anyways.
Old Jan 28, 2009 | 09:31 PM
Hexxum001's Avatar
You will max out your injectors or be close to maxing them out. That's just asking for problems. I am right at 400whp and I am running 550cc injectors, Walbro 255 and the 2.87 pulley and my G runs very nicely.
Old Jan 29, 2009 | 12:37 PM
ska12's Avatar
how much faster was it after upgrading the pulley? And how did the gas mileage change? also what type of ecu do u have?
