Holy cow monster G35 sedan build from SP....stolen from other site
Old Nov 5, 2009 | 09:17 AM
  #31
powerhousefan's Avatar
quick update - the car just hit 500 miles on the new motor. everything looks good and if all goes well, it will be going back to the shop next week for high boost, nitros and race gas tune. i'll keep you guys updated on what's happening.
in the mean time, here is a little video i put together. thanks to vr3 for coming out this past weekend.
Old Nov 5, 2009 | 09:23 AM
  #32
GreenGoblin's Avatar
The goblin resurrection
Awesome I cant wait for this to go down the track, on high boost.
Old Nov 6, 2009 | 12:40 AM
  #33
NaiveRapture's Avatar
Man that thing is totally nuts!
Old Jun 24, 2011 | 02:08 AM
  #34
Andrei's Avatar
The sedan got to 951 wheel horse power at 30 psi.
Originally Posted by Reid@SP
The car makes approximately 1300HP to the crank with the TH400 trans!!
Final Number: 951whp @ 30psi
There is a lot of room left in this setup. The turbos won't lose their efficiency until well into the high 30psi realm if not higher. This will be an excellent start to get Vlad deep into the single digits.
Old Jun 26, 2011 | 11:38 AM
  #35
CrazyG's Avatar
That's impressive!!!!!!!
Old Jun 26, 2011 | 12:13 PM
  #36
PAIXAO's Avatar
Damn.....thats nice.
Old Jun 28, 2011 | 03:38 PM
  #37
B T's Avatar
B T
is that a remotely actuated dump pipe towards the rear of the exhaust? I don't see why thats not done more often... Awesome build brother
Old Jun 28, 2011 | 04:06 PM
  #38
WhosUrBuddiee's Avatar
Why not just do a LS7 swap and be done with it? The VQ platform is a waste of money.
Old Jun 28, 2011 | 04:15 PM
  #39
da mayor's Avatar
why is it a waste? vinny ten racing has their 9-second Z w/ the Rosselier 3-speed tranny running mid 9's from a built VQ and the 6MT 350z running 10.4 all day daily driven street car
i cant wait to see what this sedan runs...
Old Jun 29, 2011 | 08:41 AM
  #40
The cost of building a 10 second VQ motor is 2-4x that of just doing a LS swap and 100 times more prone to failure.
Plus when you do run into a problem on your monster VQ build, there is only 2-3 shops in the country that can fix it. While just about every shop there is knows how to work on a LS motor.
Plus when you do a 800-1000 hp VQ, pretty much every single part is custom and expensive as can be. While parts for a 800-1000 hp LS motor can easily be found on the shevles and relativly inexpensive.
Plus sound. No matter what you do to a VQ it will never sound as good as a V8.
Old Jun 29, 2011 | 02:42 PM
  #41
Andrei's Avatar
I can agree with you this time. The problem with an LS swap in a VQ car is that the car wont retain a lot of factory functions and actually it will be more expensive to replace because it has a lot of custom work to make it work.
The problem GM has is that they put decent motors in heavy cars with the exception of the Corvette. The G8 and Camero are a waste of useful horsepower. But the VK56 is still better than a 6+ liter LS.
Old Jun 29, 2011 | 03:20 PM
  #42
thatoneguy's Avatar
^ You're also comparing a push rod OHV V8 with only .6l of displacement more to a DI, DOHC v8. I'd say the difference is not that much. Plus, the weight of the camaro is not that bad. It only weighs ~200lbs. more than a G37 Coupe, and it's got 100hp more. Here the Coyote on the same Dyno the SS and the M56 were tested on. No DI, and .6L less than the VK.
All 3 of these engines are pretty close to each other, and they all accomplish a similar end result, they just go about it in a different way.
And it is still cheaper to mod an LS than the VK.
Old Jun 29, 2011 | 04:48 PM
  #43
Actually a LS swap retains every single factory function and requires very little to no custom work. Hinson Supercars makes a VQ to LS swap kit for the 350Z and G35 for only 5k (you provide motor and trans). Come with every single thing you need including motor mounts, custom driveshaft, exhaust, and even do the Infiniti to GM ECU wiring. They even provide unlimted technical help for doing the swap.
They actually will do a full turn key build for you as well which even includes dyno/tuning. Cost is about 20k. Still SIGNIFICANTLY cheaper than doing a stroker VQ motor. Plus you would have a much stronger bottom end and overall twice the potential.
I promise you I could have them do a full LS swap with custom turbo for less than 30k, pushing 800 hp easily. While my friend Christian paid 25k for a GTM twin turbo kit and that is still stock block. XKR is well known on here, he has a 1008hp G35 coupe and has reciepts to show all the work to get to that point. He has spent over 80k in engine modifications (including quite a bit of sponsoring), while SpyderZ has only about 20k into his LS2 powered. (I believe he is now upgrading it to a LSX).
Old Jun 30, 2011 | 02:41 AM
  #44
Andrei's Avatar
The VK DI trumps the LS and 5.0 in how much torque it delivers at low RPM, which also means it has better throttle response. Either way, the sad part is that there is no manual option for the VK. And I agree the VK is more expensive to mod, mostly because no one has a Nismo budget or Nismo support in the states.
Those people spent money the wrong way. They are incapable of doing anything themselves and paid for it in full. I estimate the cost of a 1000whp VQ to be less than 20k, maybe even 15k including the turbo kit.
Old Jun 30, 2011 | 06:33 AM
  #45
gabe3d's Avatar
Hope you are kidding about that statement...
