P1122 & p1126
Old Feb 4, 2009 | 08:49 PM
djamps's Avatar
P1122 & p1126
Both these codes just popped up the other day while I was idling letting the car warm up. I already found the code definitions so theres no need to repost them here. Throttle body position relay and actuator malfunction I guess. I did some searches and most people say their car goes into limp mode and they need a new TB...mine is running perfectly fine and still idles and bones out just fine. I'm taking it back to the shop soon for an checkup anyways but just curious if anyone has any experience with these codes.
Old Feb 5, 2009 | 08:01 AM
str8dum1's Avatar
ya i've seen those. the auto shop wont tell u anything. just means your TB got stuck and will fail soon.
Old Feb 5, 2009 | 08:06 AM
djamps's Avatar
Thanks man thats what I was afraid of.
Cheers
Old Feb 5, 2009 | 08:23 AM
escobar929's Avatar
yea TBs go bad pretty often on these cars
Old Feb 5, 2009 | 01:30 PM
superchargedg's Avatar
I have had 2 fail...but they only cost me $149 with gasket.
Old Feb 5, 2009 | 01:46 PM
darkbrown1's Avatar
Do you guys mean the serpentine and TB. Are they easier to change in these cars or something? I recently had mine to crack severely and I onll have 40,738 miles on my 2004 at the time when they caught it it was like 38,500 or something.
He gave me the bad belts but I swear it took and hour to fix. In my experience I thought changing the TB and serpentine belt would take 4ever !
on .........I think I may have said some things wrong or used incorrect jargon. I work in accounting not the garage.
Old Feb 5, 2009 | 02:03 PM
escobar929's Avatar
^huh? wha chu talkin bout willis?
Old Feb 5, 2009 | 04:15 PM
djamps's Avatar
Muffler bearings? LOL
I cleared the ECU and the codes haven't come back after a few drives. Fingers crossed...
Old Feb 5, 2009 | 05:19 PM
Mine just threw the codes up the other day and the car wouldnt rev.I pulled off the side of 695(in rush hour btw)and restarted the car....drove fine and cleared the codes the next day.
So far so good but i do have a spare TB in the trunk with tools just in case.
Old Feb 5, 2009 | 06:53 PM
G37Rider92649's Avatar
I had the same exact codes you had. And I just continue droving and full throttling it all day with no problems what so ever Weird huh? But after I got a re-tune by a better tuner it went away, not saying that tuning had to do with these codes at all.
Old Feb 5, 2009 | 08:15 PM
clifftrail's Avatar
Pretty sure they are referring to the throttle body and not the timing belt.
Old Feb 5, 2009 | 10:00 PM
djamps's Avatar
Naw pretty sure the tune can't cause this, most likely the combination of 15 degree weather and murphy's law. Either way it's fine now after resetting the ECU. If it pops up again I'll swap out the TB.
Old Feb 11, 2009 | 11:28 PM
djamps's Avatar
Did ur codes come on like a second after starting it up or after running a while?
Old Aug 23, 2009 | 12:00 AM
Deezflip's Avatar
lil bump...
You guys know anyone selling a throttle body?
https://g35driver.com/forums/g35-sed...er-5mph-2.html
https://g35driver.com/forums/wanted-...baltimore.html
Old Aug 23, 2009 | 12:16 AM
djamps's Avatar
I have one unused, still in the box.
