6mt max whp rating
Old 02-26-2009 | 02:48 PM
Skaterbasist's Avatar
Retired SuperMod
Originally Posted by Krispyklene
360ish is probably an easier obtainable goal. i'm not sure why everyone's saying you need 10 grand to make a motor that powerful.... i've seen a vortech kit go for 2500 brand new from one of the vendors. install should be 1000-1500. tuning another 1000. so that's a bout 5 grand.
2500 brand new Vortech???
Even if it did run that low, lets do some numbers:
-Vortech tuner kit $2500
-Utech EMS $800
-Injectors + fuel pump $700
-Basic supporting mods which you will need to get to 360 whp on a Vortech ~$2000 (ie. exhaust, spacer, test pipes)
- Gauges (a must for forced induction) $1000+
- Tune $600+
- Installation $1000+
And these are all very conservative prices. Doing everything right needs $$$. If he really has great hookups, then that's great for him. But ballpark range for F.I is always 8-10k without doing anything to the internals.
Old 02-26-2009 | 03:05 PM
escobar929's Avatar
your def not gonna do it for under $8k, unless you find a used kit that comes w/ everything you need and then you install it your self
then, maybe $5k might do it. i know someone who did it for a lot less but he was the exception that proves the rule
Old 02-26-2009 | 06:26 PM
sharif@forged's Avatar
Vortech Tuner Kit $4000
UTEC and pressure Sensor $900
Walbro Pump $90
DW 600cc Injectors $550
Installation: $1800
Tuning $500
$7840 for a clean basic safe setup. You don't HAVE to get exhaust and gauges. Of course, this is a good starting point, and you are correct, that most people do get cages, and upgraded clutch/exhaust. But not required.
Old 03-13-2009 | 12:19 AM
thom000001's Avatar
Not quite
Trans was fine. It sheared a rear-end gear due to the DSS halfsahfts being slightly too short and not fully engaging the gear. This issue has been resolved though. Still on stock 6spd and stock 3.5 diff.
tom
Originally Posted by mjwaterma
Sound Performance here in Chicago is pushing over 1000 whp on a stock trans in their 350Z. They ended up shearing the input shaft while trying to launch it with slicks though. http://www.chicagoz.com/forums/showthread.php?t=14974
Old 03-13-2009 | 03:32 PM
ttrank's Avatar
Grocery getter
My issue is more with the rear diff and track days.
Old 03-13-2009 | 03:58 PM
bluemax189's Avatar
Walbro Pump $90
Installation: $1800
Tuning $500
where are you finding new tuner kits for 4k???? not even your website has that kind of price.
suby01
Not G35 Related
05-25-2016 03:07 PM
g.spot
05-09-2016 10:54 PM
AJC128
11-01-2015 11:55 AM
wow600rr
09-28-2015 11:50 AM
Detailed Image
09-28-2015 07:04 AM
Quick Reply: 6mt max whp rating
