6mt max whp rating
Old 02-25-2009 | 02:57 PM
boost420's Avatar
6mt max whp rating
just wondering how much abuse(whp) an 04 and 05 g35 6mt can take reliably?, I was thinking around 400whp . thanks
Old 02-25-2009 | 03:12 PM
vhtran's Avatar
What are you trying to get out of this?
Old 02-25-2009 | 03:14 PM
Hi-TechG35's Avatar
Old 02-25-2009 | 03:17 PM
boost420's Avatar
Well for starters let me apologize for posting this in the wrong forum, just found the engine forums. As to your question, i ask this because i am trying to figure out what steps i want to take when the mod bug hits.(sort of kind of a tight budget) thanks
Old 02-25-2009 | 03:19 PM
PAIXAO's Avatar
400hp + tight budget = fail
Old 02-25-2009 | 03:23 PM
Texasscout's Avatar
Must agree with TwilightBlue
320 WHP from Naturally Aspirated gear = many dollars
400 WHP from FI = same dollars but easier.
There is no such thing as a "tight budget" with a VQ motor.
if you want to turbo/super charger and do it right, look at spending 8-10K on kit and a tune, and that's with NO internal motor work.
Old 02-25-2009 | 03:28 PM
boost420's Avatar
400hp + tight budget + A good amount of connections.......GREAT SUCCESS(Borat)
Old 02-25-2009 | 03:29 PM
boost420's Avatar
thanks texas, yeah im not a huge fan N/A definitley going turbo, single preferably
Old 02-25-2009 | 04:32 PM
keff108's Avatar
Anything FI= MONEY
Old 02-25-2009 | 04:50 PM
mjwaterma's Avatar
Sound Performance here in Chicago is pushing over 1000 whp on a stock trans in their 350Z. They ended up shearing the input shaft while trying to launch it with slicks though. http://www.chicagoz.com/forums/showthread.php?t=14974
Old 02-26-2009 | 10:01 AM
sharif@forged's Avatar
The transmission is stout. Good triple disc carbon clutch, and she'll hold 800whp+
Old 02-26-2009 | 10:12 AM
escobar929's Avatar
transimission will be the last thing you worry bout, just upgrade to a JWT clutch/flywheel and 400rwhp will be no problem for the transmission
Old 02-26-2009 | 11:07 AM
XKR's Avatar
XKR
Originally Posted by sharif@forged
The transmission is stout. Good triple disc carbon clutch, and she'll hold 1000whp+
FIXED ****
Well...we will find out for sure at the end of next month if it can handle 1000+
Old 02-26-2009 | 11:35 AM
Krispyklene's Avatar
360ish is probably an easier obtainable goal. i'm not sure why everyone's saying you need 10 grand to make a motor that powerful.... i've seen a vortech kit go for 2500 brand new from one of the vendors. install should be 1000-1500. tuning another 1000. so that's a bout 5 grand.
Old 02-26-2009 | 02:02 PM
Sub 400whp definately does not need a built motor.
On a budget, I think a Vortech Tuner kit with UTEC injectors, pump, and tuning would be perfect. Very safe too. Under $8K installed and tuned.
Quick Reply: 6mt max whp rating
