Aps single turbo kit
So i bought this kit for my 04 5at g35....I was wondering if it is nessacary to add pistons and rods....i have 78K on it now...im only planning to run 350whp...so far i upgraded my torque converter, tranny cooler...the kit comes with a unichip...is that good enough...how much would you estimate for a turbo,piston,rod,sways,tranny cooler, and exhaust system...the shop im looking at charges $65 per hour..more than $1000? should i even turbo the car or should i just sell the kit? its my DD. Thanks guys
i have been looking but they are being answered indirectly...plus i think my situation is at least half unique...but i called World motorsports and they said at a low boost and 350whp should be fine...i wouldnt need pistons anything high then maybe
I think you should be fine. I'm running the APS ST and 350 whp is where I'm at with a very conservative tune. You should be fine, but problems always do come up when you go FI so keep that in mind... Just because we say you should be fine doesn't always mean you will be.
yeah i bought i ton of cooling mods too...i got a tranny cooler...oil cooler...mishimoto radiotor...nismo thermo...greddy oil catch can...and Rear Coolant Bypass System...spent like over $1000 in just cooling mods...spent $3000 on the used Turbo kit w/ APS true duel exhaust...i also bought front and rear sways, stop tech stage 2 OEM kit with cross drilled rotor...i spent alot of money in just supporting mods...and probably spend another $2000 to get everything installed!....cant wait.
Guest
Posts: n/a
Sounds like you got your bases covered. I'd be more concerned about the tranny then engine. Even though 350whp is a pretty safe bet, the tranny the will go before the engine on that (if turned correctly). AKA, get a valve body within a few months.
boostelevator
Engine - Power Adders
Sep 9, 2015 05:56 PM
JG_G35
Engine - Intake/Fuel
Sep 7, 2015 09:35 PM
