Are rc750cc injectors to big?
Old Aug 31, 2009 | 12:08 AM
G35-31's Avatar
I'm going with a used greddy tt kit and it doesn't have injectors I can get a great deal on 750cc injectors but don't know if there to big and will give me problems on a stock motor set up ?
Old Aug 31, 2009 | 01:22 PM
TTG35forT's Avatar
The larger the injectors, the less granularity you have for tuning. But they will work.
Old Sep 5, 2009 | 12:37 PM
Bestswat's Avatar
overkill..if your not making big power.
Old Sep 5, 2009 | 12:56 PM
TTG35forT's Avatar
If you think you might want to upgrade to a built motor setup sometime in the future, and you don't want the expense of buying another set of injectors, then I would go with the 750cc injectors.
If you never plan on upgrading the block (eventially the stock block is going to give out, sooner or later), then go with smaller injectors. They make tuning the motor easier.
That said, Japtrix had my last motor idling and starting very smoothly with 1,000cc injectors. Then again, I had an F-CON V Pro, which has better resolution for tuning than a Utec.
g.spot
May 9, 2016 10:54 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
yosip1115
16
Sep 28, 2015 04:14 PM
