Cookin' Rice! - Nitrous Installed G35 Sedan 2004.5
Old Sep 20, 2009 | 03:18 PM
liche's Avatar
Just about finished my nitrous install on my 2004.5 G35 Sedan (6MT). Here is what I did so far . . .
1. Replace plugs NGK Copper LFR6A-11 (0.035 Gap)
2. Zex 350Z Wet Nitrous Kit
3. Zex Bottle Warmer
4. Zex TPS Switch / Window TC Module
5. Uprev Osiris Engine Management (will have Dyno Tuned)
Already have JWT PopCharger, Z-Tube, 5/16" Plenum, and Stillen Catback Exhaust, as well as Stillen Sways.
Yep - pretty damn Rice, but unfortunately, I don't have the 10-12k to drop on a twin-turbo at the moment . . . as much as I'd like to . . .
Some install photos here. Took me about 18 hours to install everything including the new plugs. Took so long since everything was run with wire looms and routed cleanly, grommets on everything, machining on the ashtray, as well as other areas which took longer than usual, not to mention i had to switch tank from left to right side of car as nitrous cable was a bit short . . . Not to mention i also had to babysit my 4 and 1 year olds at the same time . . .
Attached Thumbnails Cookin' Rice! - Nitrous Installed G35 Sedan 2004.5-rice01.jpg   Cookin' Rice! - Nitrous Installed G35 Sedan 2004.5-rice02.jpg   Cookin' Rice! - Nitrous Installed G35 Sedan 2004.5-rice03.jpg   Cookin' Rice! - Nitrous Installed G35 Sedan 2004.5-rice04.jpg   Cookin' Rice! - Nitrous Installed G35 Sedan 2004.5-rice04a.jpg
Old Sep 20, 2009 | 03:23 PM
liche's Avatar
More photos . . .
Attached Thumbnails Cookin' Rice! - Nitrous Installed G35 Sedan 2004.5-rice05.jpg   Cookin' Rice! - Nitrous Installed G35 Sedan 2004.5-rice07.jpg   Cookin' Rice! - Nitrous Installed G35 Sedan 2004.5-rice08.jpg   Cookin' Rice! - Nitrous Installed G35 Sedan 2004.5-rice09.jpg   Cookin' Rice! - Nitrous Installed G35 Sedan 2004.5-rice09a.jpg
Old Sep 20, 2009 | 03:26 PM
liche's Avatar
and a few more . . .
Attached Thumbnails Cookin' Rice! - Nitrous Installed G35 Sedan 2004.5-rice09b.jpg   Cookin' Rice! - Nitrous Installed G35 Sedan 2004.5-rice09c.jpg   Cookin' Rice! - Nitrous Installed G35 Sedan 2004.5-rice09d.jpg   Cookin' Rice! - Nitrous Installed G35 Sedan 2004.5-rice09f.jpg
Old Sep 20, 2009 | 03:28 PM
HenryLee's Avatar
wow. looks fun.
Old Sep 20, 2009 | 03:30 PM
O HELLA OEM's Avatar
nice!
jw why do you have 2 switches?
so if you press 1 of the switches
you will have an instant boost?
jw
Old Sep 20, 2009 | 03:41 PM
officerdbag's Avatar
how much did this all cost you?
Old Sep 20, 2009 | 05:58 PM
XKR's Avatar
XKR
I wish you the best of luck on this setup......I am not a big fan of NOS on stock motor
Old Sep 20, 2009 | 08:56 PM
Sylvan lake V35's Avatar
Looks good. Did you not run fuel into the box as well? It looks like one port has not been hooked up on the box? What size shot are you planning to run? Should be fun
Old Sep 20, 2009 | 09:08 PM
Locksmith's Avatar
Looking good
Old Sep 21, 2009 | 06:35 AM
liche's Avatar
Thanks for the comments!
Anyways, to answer some questions, the two switches are the following: One is the primary arming switch, and the other is the switch for the bottle warmer. The nitrous will activate at full throttle and from approx. 3k-6k RPM in gears 2+.
Yep, not finished yet. The only thing left to do is wait for my Nitrous Permit (YES you need one to buy nitrous in NJ) and hook up my fuel line.
Thanks!
Old Sep 21, 2009 | 07:04 AM
Marinelli Motorsports's Avatar
Wow. Learn something new everyday
Old Sep 21, 2009 | 07:33 AM
liche's Avatar
Yeah, NJ. You even need a permit to wipe your ****!
Old Sep 21, 2009 | 12:53 PM
rcdash's Avatar
Clean install! Nice work on the ashtray!
Yep, I've been thinking of a 200 shot on my built motor. What do you think about that? Oh yeah, I'll still be about 300 whp shy of what I need for ZdayZ.
Old Sep 21, 2009 | 01:10 PM
XKR's Avatar
XKR
You dont need NOS Raj....You are already out- running Sharif's GTR
Old Jan 3, 2013 | 03:33 PM
JDMswagSerf's Avatar
what is that box used for? and what's in the upper dash compartment?
