Gauges
Old Nov 9, 2009 | 05:25 PM
bigc's Avatar
Wings Nation
gotcha
fwiw, the plx pulls up most of the data it says it will, but it doesn't give you fuel pressure or EGT
Old Nov 9, 2009 | 10:50 PM
GT-ER's Avatar
Originally Posted by bigc
my350z will have more information on safe operating ranges, particularly for ppl with boosted cars. i've seen the info over there, you just need to search around a little. from what i remember though, coolant temps should stay below 210F (this is the hi temp trigger on your fans), AFR should be 14.7 (if NA) or 11-12 (if FI), and stock fuel pressure is around 52 PSI.
A/F ratio should NOT be 14.7 if NA...they should only be 14.7 during part throttle driving regardless of your car being NA or FI. At WOT they should probably be in the high 12's NA and high 11's FI give or take.
Old Nov 10, 2009 | 12:22 AM
bigc's Avatar
Wings Nation
for the sake of simplicity, i provided the stoichiometric AFR for an NA engine. yes, this is mostly seen at idle & cruise (which is the primary time when you'll actually be able to look at the gauge, lol), but you'd run slightly richer at WOT to get max power. most NA cars will run even richer / lower AFRs (12s & 13s) for added safety and emissions.
FI cars are a whole other story
Old Nov 18, 2009 | 12:40 AM
sliderg35's Avatar
I vote A/F, Oil Press, Boost, Tranny Temp (Auto) or EGT (Manual). It's really not necessary to read water temp down to 1 degree resolution - the stock guage will tell you quite nicely if you are running hot or not.
Old Nov 18, 2009 | 08:07 AM
djamps's Avatar
Do your nexus gauges sometimes not turn on (one or more of them) if you start the car too fast? I've noticed mine have to be allowed to begin their 'init' sequence before starting the car or they never come on... been driving me nuts.
Old Nov 20, 2009 | 07:39 PM
sliderg35's Avatar
Simple fix... I just turn the key to "ON", wait for the Walbro to spin up and get pressure (1000, 2000) then turn the key to "Start". It works every time - No more trouble.
Old Nov 21, 2009 | 10:08 AM
djamps's Avatar
True, but it doesn't take 5+ seconds for the Walbro to spin up. That's how long you have to wait for the gauges to initialize properly before you start it. In fact, even the remote start causes the gauges to malfunction so I don't even use that anymore.
Even when they are working, you can't see them very well in bright light. If you're wearing sunglasses it's even worse, don't even bother looking at them.
No audible warning capability even though they make a loud beep when you turn them on.
They are loud as hell during init/shutdown.
No serial output for external data logging
I could go on....
POS gauges.
Especially given the ridiculous price tag, I would never, ever recommend these gauges to anyone.
Old Nov 21, 2009 | 11:06 AM
GT-ER's Avatar
How does it take you guys 5+ seconds for the walbro to spool up? I had a walbro in my GTI and I would start it just like every other car and it would start up instantly.
Old Nov 21, 2009 | 12:14 PM
djamps's Avatar
Did you even read my post? Jeez, this has ABSOLUTELY NOTHING TO DO WITH A WALBRO nor did I state it takes that long.
Old Nov 21, 2009 | 12:37 PM
silver g's Avatar
+1 Under normal driving conditions A/F should be in the mid 14's under WOT between 11 and 12. I would say anything higher than 12 at WOT is too lean for FI.
Old Nov 22, 2009 | 05:10 PM
liche's Avatar
When you get your car tuned, make sure they have a "power" map and also a "fuel economy" map. The power map will be tuned richer, while the fuel economy map (for regular cruising) will be tuned leaner for better fuel economy. Obviously, you won't want to be boosting in the fuel economy map, but it will make a huge difference in fuel economy. I get about 5 MPG more with the fuel economy map on my car, so it does save me a lot of money on gas.
Old Nov 22, 2009 | 07:06 PM
GT-ER's Avatar
Oopss...I read does instead of doesn't... you don't have to blow up though.
Old Nov 22, 2009 | 07:32 PM
sliderg35's Avatar
I only switch "on", count 1 - 2, then go to start - I do not let the gauges go through the full startup before starting the car. Give that a shot. If you find the amber hard to see, try the white.
I did get a replacement gauge from Autometer once and the glass was much darker than my other gauges. I ended up not using that one because it was too dark. Yours may fall into that category - get Autometer to replace it.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
alessandro
Oct 8, 2015 09:29 AM
9tray turbo
Sep 29, 2015 10:22 PM
JustinMKN1
Sep 18, 2015 03:40 PM
