need help with a vortech tuner kit
Old Nov 19, 2009 | 11:39 PM
856_reilly's Avatar
Angry need help with a vortech tuner kit
i wrote another thread i forgot to ask should i put test pipes on before i get it tuned i all ready have cat back hks
Old Nov 22, 2009 | 05:06 PM
liche's Avatar
YES YES YES.
Make sure you have everything you need on your car when you get it tuned. Otherwise, you'll have to get it retuned if you make a change like that.
And yes, HFCs are required for FI. Your car will be running too rich to be able to use stock cats - they'll just get fouled up and clogged, plus if you have lots of miles on your car, you have no idea what condition they are in now anyways.
I had to choose between race pipes and HFCs and decided HFCs since i didn't want the raspiness of race pipes. I used Fast Intentions 300 Cell HFCs. Awesome! Just make sure to have them add an extra bung on each CAT. One for your A/F gauge (should you have one), and also one for your tuner so he can put one on for tuning. And make sure to have them install the bungs on the topside so you don't have the wideband sensor underneath where it can get damaged by condensation.
Old Nov 22, 2009 | 10:32 PM
856_reilly's Avatar
help w the charger
thxs bro you said alot of detailed stuff more then ive gottin out of anybody else thanks!!!!!!!!! But i dont have the extra bung lk you said guess ill have to do w what i got> It can still b done tho right? and also can i use 440cc injectors with the upgraded pully to get the extr 3 lbs of boost? and id it reliable with a stock motor?
Old Nov 23, 2009 | 07:41 AM
liche's Avatar
The vortech with the 3.12 pulley is about the limit for the stock G35 motor and will give about 10psi.
Who is going to do your tune?
If you don't have one yet, call Hok down at JTune Performance. He's much much more knowledgeable than me and will answer all your questions right over the phone regarding injectors, etc...
Old Nov 23, 2009 | 07:44 AM
liche's Avatar
BTW . . .
R/T Tuning in Lansdale, PA has a Vortech special going on.
Vortech Tuner Kit
440 Injectors
Walbro Fuel Pump
FULL INSTALL
Osiris Tune
for about $6000.00
You can't beat that!
http://rttuning.com/
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
JG_G35
Engine - Intake/Fuel
Sep 7, 2015 09:35 PM
n2fooz
Sep 4, 2015 07:46 PM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
