BOV question!
Old Dec 3, 2009 | 10:50 PM
ezpotato's Avatar
BOV question!
Got an khs bov with my vortech setup. a few weeks after getting it installed, the bov was pretty "open", meaning it was blowing out a lotta air... so got it "tightened" and it was a lot quiter and not so wide open all the time. Well, now it's again to the point where if i just stand nextr to the car at idle, it just shoots air out, i can feel it about 5-6 feet away from the car even. can i get it adjusted aghain or is there something wrong with it? it's only been 3 months since i got it fixed.
sorry for the quotations, i am not too familiar with bov technology, so i'm using the best terms i can. basically it's open all the time and it's SUPER loud!
Old Dec 3, 2009 | 10:52 PM
Dustin@StrafeAutomotive's Avatar
Really Needs a Life
im not sure, pm kris79 about this i know he is running another bov w/his vortech..
Old Dec 3, 2009 | 11:03 PM
booger's Avatar
The BOV maybe set up to be open while not boosting and close when vacuum drops to build boost . This would be normal operation of it . This is how Vortech's bypass bov works any how .
Old Dec 4, 2009 | 10:16 AM
liche's Avatar
The Bypass Valve (its not a BOV) is supposed to be fully open when not under wide open throttle. In otherwords, when the manifold pressure is less than the intake pressure (under vacuum or partially closed throttle plate), the BV will be open. Only during WOT will the valve close.
The valve activates by a simple mechanical pressure switch which compares the manifold pressure to the intake pressure. The screw on the valve can adjust at which pressure it will open etc... It should tell you more of this in the manual.
Old Dec 5, 2009 | 11:31 AM
booger's Avatar
Originally Posted by HomieG35
My GReddy Type-S does the same... will even whistle with the ProCharger at times.
I want that SC Homie....need to put one on to sell the car .
Old Dec 5, 2009 | 03:59 PM
ezpotato's Avatar
its weird cause it didnt always blow that hard at idle, and it's soooooo loud. it to the point wehere i hate driving around a neighborhood at night cause it gets sooo loud. i dont remember it being like that.
Old Dec 6, 2009 | 06:40 PM
EGGPLANT's Avatar
put the vortech bypass back on.. or get the greddy type - S BOV which fits right on the piping...
migurus
Sep 5, 2015 09:39 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
UT G35
Sep 3, 2015 03:58 PM
TheBay
Sep 3, 2015 03:27 PM
erich2780
Sep 3, 2015 03:23 PM
