should i change my headers if i s/c
Old Sep 6, 2004 | 11:31 PM
josahn's Avatar
not sure if i will see any gain.
Old Sep 7, 2004 | 12:31 AM
KPierson's Avatar
Re: should i change my headers if i s/c
It all depends. Once you pressurize the intake side of your engine you will need to open up the exhaust side. If the exhaust creates enough backpressure your boost will be worthless. You have to let the engine breath.
Kevin
www.KPtechnologies.net
AIM: KPiersonTec
04 DG Coupe / VDC Memory
OEM Remote Window up mod
Procharged / Crawford / TS
Old Sep 7, 2004 | 03:52 PM
Walser's Avatar
Supercharged engines love headers, provided you have the rest of the exhaust unrestricted.
Whatever gains you would see N/A will double with the SC.
Old Sep 7, 2004 | 08:12 PM
narkotic's Avatar
You will not see enough gain to warrant the price ratio.
Old Sep 8, 2004 | 10:59 AM
tig488's Avatar
the sc needs a little backpressure or you will not be able to built adequate boost, my vortech, felt stronger once i removed my injen exhaust, and left on my test pipes with the stock exhaust.
[image]cant get the damn thing to work[/image]
Vortech blown 03 coupe with 371 horses, sponsored by: TopSecret,Brembo,Cusco,KGMM,Volk,Injen,Alpine,JL,
-yeah right.
Old Sep 8, 2004 | 12:56 PM
GlenRoseFireFighter's Avatar
a.k.a. RANDYS_G
felt stronger, but was it? What did the dyno say? I ask for 2 reasons, one, I am going FI in a week or so and have the Injen exhaust...two, it felt like I actually LOST ponies by adding the Injen exhaust, but a recent dyno day showed a 25 pony gain over stock...I have cats too, but I'm sure the exhaust helped. I put 265 to the wheels with the mods listed in my profile...(exhaust, cats, short ram intake)
2 G or not 2 G, there's no question!
Old Sep 8, 2004 | 12:59 PM
a.k.a. RANDYS_G
Nark, do you have a wideband A/F? If so, which one and where to get it, if not, why not? Do you have an Oil Pressure gauge...same questions.
Tig, same questions.
Old Sep 8, 2004 | 02:31 PM
narkotic's Avatar
Nope, only reason I see to own a wideband is if you like to tune yourself. I had mine dyno tuned and never needed one. I have however installed an EGT gauge on cyl 6 to monitor exhaust temps. Fuel pressure as well since I have 2 fuel pumps and want to make sure both of them are working in tandem.
Old Sep 8, 2004 | 04:04 PM
a.k.a. RANDYS_G
why two fuel pumps? I'm getting the Vortech system, will I get/need two pumps?
Old Sep 8, 2004 | 04:48 PM
jimthegreek02's Avatar
the vortech kit comes wiht a aux. fuel pump from what i was told....
Also, most people notice that with the stock exhaust and FI, they get better numbers such as I with the Stillen.
Injen has my car again today for the wek, they are revamping the exhaust. =)
Stillen Stage 2 Supercharger, Stillen Front Bumper, Stillen Carbon Fiber Hood, Injen SES Cat-back Exhaust, Injen Cold Air Intake, 19" Axis Hiro Anthracite, Clear Corners
Old Sep 8, 2004 | 05:06 PM
a.k.a. RANDYS_G
I'm assuming they get better #'s cuz of the Y-pipe...causes more compression, where the Injen is more OPEN...BTW, I haven't called Duy yet, but my ish is still blowing fiberglass all over the @ss end and one tip (driver side) still turns black, while the other doesn't...I was waiting to tell him if the rasp comes back from all of the fiberglass blowing out...I thought this system was from the new run? Pisses me off cuz I had that damn rental with bad breaks for a whole week and it seems like I have the same exhaust system again, minus the rasp...in time though, it'll be back too.
Old Sep 8, 2004 | 05:11 PM
That sucks and sorry to hear that. The new exhausts are being test fitted on my car as wel speak and they are dyno'ing my car and trying to come up with different approaches and get some ??? answered.
celwin
V36 Engine, Exhaust, Drivetrain & FI
11
Sep 28, 2015 03:52 AM
Albanian122
Engine - Exhaust
Sep 5, 2015 11:23 AM
TrillO.G.35
Sep 5, 2015 02:06 AM
mikemf8
Sep 3, 2015 08:01 PM
linedr89
Aug 17, 2015 05:11 PM
