TT Track Junkies...Need your Input!
Old Apr 21, 2010 | 03:31 PM
Sylvan lake V35's Avatar
Originally Posted by BrianlG35C
It dose not reduce overall coolant temps just helps keep coolant temps from racing.
Old Apr 21, 2010 | 06:39 PM
terrasmak's Avatar
G Sedan
Hopefully i'll get a chance to look at your car this weekend. I really hope that moving the trans cooler to the underside may work. It does block a large section of the radiator. The only 2 FI cars with problems i know are auto, and both from Relentless.
Old Apr 23, 2010 | 01:21 PM
Canadian's Avatar
Canada, eh?
Anyone who has the GTM fan shroud can you comment on the effectiveness of it? I know it's expensive as fawk but if it will make that big of a difference I will consider it.
Old Apr 27, 2010 | 01:26 AM
Canadian's Avatar
Canada, eh?
Old Apr 27, 2010 | 01:29 AM
bigc's Avatar
Wings Nation
its a fan shroud with two SPAL fans bolted to it. you can save yourself ~$200 by buying a mishimoto fan kit and swapping out the mishimoto fans for SPALs. whichever route you go, you'll have to do your own wiring and/or get a standalone fan controller.
Old Apr 27, 2010 | 02:42 AM
Canadian's Avatar
Canada, eh?
Why do you have to do your own wiring or get a fan controller? The kit says it comes with everything required. I don't care about them being loud.
Maybe Ill get the mishimoto kit and swap out the fans.
Old Apr 27, 2010 | 03:12 AM
bigc's Avatar
Wings Nation
the fans have 2 conductors each, but the OEM fans have 4 conductors each. its not as simple as twisting wires together. if you want the ECU to control the fans using the OEM coolant temp sensors, you need to connect the wires to the OEM harness in a specific manner. alternatively, there are aftermarket controllers that can tap into the OEM sensor and provide greater control over the fans (lower turn on point, variable speed, manual operation, etc).
these two threads provide the wiring diagram you can use to connect the fans to the OEM fan harness:
http://my350z.com/forum/engine-and-d...an-wiring.html
http://my350z.com/forum/engine-and-d...ator-fans.html
Old Apr 27, 2010 | 01:43 PM
istan's Avatar
Wiring isn't an issue. We solved that a long time ago
I'm on the Mishimoto after my FAL fans melted on me . I'm running a very similar cooling setup and I have issues on the street still. I cannot for the life of me figure out why we're overheating so damn much.
Old Apr 27, 2010 | 10:28 PM
I got the Mishis I wired them to the stock fans wiring and they are controlled by the stock ECU. i might switch control of the fans to my Vi-PEC though.
Old Aug 13, 2015 | 11:08 AM
eZg's Avatar
eZg
For the life of me I an NOT find a wiring diagram of the cooling fans in the FSM?!?
I want to run relays to handle much larger fans and need to know which factory wires are triggers and which are ignition. (prob not proper terminology as I am referencing Spal wiring diagrams)
Anyone know what pages in FSM might have wiring diagrams showing this info??
Thanks
Old Aug 13, 2015 | 03:28 PM
bigc's Avatar
Wings Nation
hope this helps - note that the wire colors may be different for your year (mine is an '05 coupe)
there's also a diagram over on my350z from when folks were wiring up aftermarket slim fans (mishimoto, SPAL, etc.). I used that diagram years ago when I installed mine - will see if I can find a link to the thread.
EDIT: Looks like you found the thread I was referring to: http://my350z.com/forum/engine-and-d...an-wiring.html
File Type: pdf
Old Aug 13, 2015 | 08:54 PM
eZg's Avatar
eZg
Thank you for the reply bigc!
I prob need to figure out how to test the wires with voltmeter some how.
Darn Revup engine. First consumes oil ..... Now tricky wiring harness all backasswards.
Old Aug 14, 2015 | 11:06 AM
eZg's Avatar
eZg
Revup cooling fan wiring diagram can be found on page 530 of the ec (engine control system) of the FSM.
Hope that saves someone the 2 days worth of searching it took me
Dallsinghjr1
Sep 17, 2023 11:25 AM
suby01
Not G35 Related
May 25, 2016 03:07 PM
AJC128
Nov 1, 2015 11:55 AM
6spdGspot
Oct 5, 2015 01:55 PM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
