TT Track Junkies...Need your Input!
Old Apr 18, 2010 | 06:31 PM
Canadian's Avatar
Canada, eh?
What do you guys do to stop your car from overheating?
I have done everything I can think of, 53mm radiator, oil cooler, nismo thermostat, water wetter..and my damn car does not stop getting too hot. The stock gauge will hit basically as high as it can go and my aftermarket gauge hits about 260. This is coolant temp, I do not know how hot my oil gets but I'm assuming it is somewhat similar.
Just got finished with my 5th track day yesterday in about 80 degree weather and after 2-3 laps on a 2.4 mile course I couldn't get on it at all.
I'm out of ideas on what else to do...but I know there are people here with TT setups that track their cars. I want your input on how high your temps get and what you have done to keep them as low as possible.
Old Apr 18, 2010 | 06:52 PM
bigc's Avatar
Wings Nation
are you still rocking the nismo front bumper with dual ICs behind the vents? if so, perhaps another bumper will allow more flow to the radiator.
Old Apr 18, 2010 | 07:16 PM
tiguy99's Avatar
What size oil cooler are you running
Old Apr 18, 2010 | 07:50 PM
TTG35forT's Avatar
I ran into a problem overheating on the track. My problem turned out to be that the Walbro fuel pump was sucking the in-tank fuel hangar dry and I was leaning out - I could see it on the AFR display at the end of long straits.
If fuel delivery is not your issue, I'm stumped. I have a Koyo radiator, two oil coolers, and the Nismo thermostat. When fuel pickup was not an issue, my temps were normal.
Old Apr 18, 2010 | 09:13 PM
Canadian's Avatar
Canada, eh?
Don't recall, but even after the oil cooler temps didn't get changed.
Fuel delivery is no problem, hitting normal AFRs. What do you mean by "normal" and what temperature was it outside? Normal as in the stock gauge didn't move after it gets to its normal position? Do you have aftermarket fans or anything else?
Old Apr 18, 2010 | 09:36 PM
GreenGoblin's Avatar
The goblin resurrection
Jordan have you done any data logging to see AIT on the track as they increase how it directly effects the temp of the car.
Old Apr 18, 2010 | 10:01 PM
Canadian's Avatar
Canada, eh?
Hey Danny..
No never done any data logging. Not too sure on how to do that
Old Apr 19, 2010 | 12:19 AM
Sylvan lake V35's Avatar
Evans waterless coolant is said to help reduce temps(I just switched over to it myself but have yet to get it back on the road) also I just switched to aftermarket fans. I would say you have done everything you can do but those two changes.
As far as data logging I think you need an aftermarket ECU and a laptop to log what your car is doing while driving. I am not sure if it can be done through the OBDII port with the stock ECU???
Old Apr 19, 2010 | 12:43 AM
TTG35forT's Avatar
At the time I was looking at the stock temperature gauge. I have the F-Con Navigator, but the display is to small to read while running around the track. The stock gauge mostly stayed in the same position where it always sits, maybe 1/3 way up from the bottom (it's been nearly two years, so I am going from memory). When I started having fuel pickup issues, the stock gauge started moving up. When I saw that it was about 2/3 of the way up, I started backing off. I then closely watched my AFR display and backed off about 1/2 way down the long straights. That brought the temperature down.
Outside temperature was mid-70's. I have the stock fan.
Old Apr 19, 2010 | 11:02 AM
Canadian's Avatar
Canada, eh?
Evans will be next when I do the motor, but I don't see the point in aftermarket fans. When you don't go below 40-50mph on the track is there really a point to even having the fans? Correct me if I'm wrong but would it even help? What fans did you get?
Old Apr 19, 2010 | 11:25 AM
RandomHer0's Avatar
I've never overheated on the track, I can easily run 20-30mins.
I have the big Koyo too, even when I had OEM rad, I never overheated.
Air in your cooling system? Thats the only time I ever overheated.
Old Apr 19, 2010 | 11:29 AM
Canadian's Avatar
Canada, eh?
I don't believe your turbos are watercooled, so your water temps wouldn't get hot like a watercooled turbo would. No air in the system though.
Old Apr 19, 2010 | 02:44 PM
I think your right the fans likely don't come on at higher speeds, I got the Mishamoto fans. I mostly got them because with my PWR rad the OEM fans were pushed up against the JWT intake piping the Mishamoto fans give a little more clearance. Another possibility is get a water sprayer (i have seen kits for this before) or rig up the Winshield washer sprayers to spray water on the rad I am not sure what EMS you have I have a ViPEC and it could control the sprayer so you wouldn't manually have to push a button. I think that option would be more for time attack as it would help cool but only for short periods or until the water runs out. I have heard more of this being used on intercoolers but the same principal would work on Rads, not sure if its a good option just throwing some ideas out there for you
Old Apr 21, 2010 | 11:43 AM
arsine's Avatar
uprev cipher and a netbook could be used for datalogging
Old Apr 21, 2010 | 03:06 PM
BrianlG35C's Avatar
Ohio G Club Member
Cooling mod? ....
http://my350z.com/forum/forced-induc...od-review.html
