<<< Jay'Z Greddy TT 20g tuned@Uprev for bigger #'s!! >>>
Old 04-27-2010, 08:48 PM
GreenGoblin's Avatar
The goblin resurrection
Awesome Jay If I make you a carbon fiber engine block can we trade?
Old 04-27-2010, 08:55 PM
Jay'Z's Avatar
I wish lol.....
Old 04-27-2010, 10:27 PM
booger's Avatar
Looks good Jay !
have fun with her .
Im going to be stock [or as close as possible ] for a while .
Old 04-27-2010, 10:29 PM
Jay'Z's Avatar
Originally Posted by booger
Looks good Jay !
have fun with her .
Havent you been there for quite a few years Sir?
I remember you stripping your car out a while back and just running a ems..
Old 04-27-2010, 10:31 PM
thom000001's Avatar
Nice Jay,
Ask how that clutch feels....I got the same one
Tom
Old 04-27-2010, 10:33 PM
Jay'Z's Avatar
It feels great, its a little harder on 1st gear, like you might as well erase 1st gear because it is too strong for 1st... Cruising in 1st makes the car jerk like crazy! lol
Old 04-27-2010, 10:36 PM
thom000001's Avatar
Thats exactly how my old clutch was (stage 5 full face, stock flywheel)....and then at 300miles it was like you flipped a switch and it smoothed out....
I'll be back in mine hopefully next week
Tom
Old 04-27-2010, 10:38 PM
Jay'Z's Avatar
Tom
Ok, not sure if im at 300 since install yet but im prob close to it... Whats ur car having done? Retune?
Old 04-27-2010, 10:43 PM
thom000001's Avatar
Oh little of this, little of that....
Clutch (stage 5 EXTREEEEEEEEEME), and light flywheel....
And BC Stage 3 cams (change from stock)
And 60mm turbos (up from current 54mm, same exhaust wheel/housing, bigger inlet wheel/housing. Should match the BC stage 3's well).
Only real goal I have is gettin close to 650rwhp on pump this time.
Tom
Old 04-27-2010, 10:52 PM
Jay'Z's Avatar
Tom
I have stage 5 too, Ceramic.. You have Ceramic or Feramic?
Old 04-27-2010, 11:01 PM
thom000001's Avatar
I have the B model too, I believe thats the ceramic. I had feramic on first clutch.
We'll see how it does....gonna give up a little tq vs old setup for way more high rpm power with the cam/turbo combo (and carry power further than 6k rpm now lol)......but that may help the clutch a little
EDIT - BTW old turbos are rated at 460hp each, new ones are rated at 590hp each lol...so slightly different!
Tom
Old 04-27-2010, 11:07 PM
Jay'Z's Avatar
GL Tom, im trying for 600+ on pump too.....
Old 04-27-2010, 11:08 PM
thom000001's Avatar
Thanks,
GL too you too.....lets see what those 20G's got in em'
Tom
Old 04-27-2010, 11:32 PM
Hexxum001's Avatar
Engine/Drivetrain Modifications:
Engine built by G&G Racing (Houston TX)
Longblock option 2
Block oil passages cleaned
Block redecked
Block Bored and Honed using a Torque Plate
Crank balanced
Crank journals polished
New Main and Rod bearings w/ceramic coating
CARRILLO Forged Rods
ARP Rod Bolts
CP EXTREME Duty Forged Pistons .020 over(9.2:1)
Ceramic coating on Piston skirts and tops
ARP Main Studs
ARP L19 Head Studs
Heads oil passages cleaned
Heads redecked
Ported Exhaust and Intake runners
JWT C2
JWT HD Valve Springs
5 angle valve job
Valve Stem Heights set
Cold Clearance set
New Valve stem seals
HKS Metal Head Gaskets
NISMO Thermostat ( LOW TEMP ) *New Nissan REVUP Oil Pump
New Nissan Cam seals
CJM Fuel return system
750cc RC injectors
Samco Hoses
Nismo Flywheel
DXD-B Stage 5- 6 Puck Ceramic Clutch
DXD Pressure Plate (3100pds of clamp load)
Nismo Diff cover with cooling fins
X02 True dual exhaust
Osiris Tuned by Jared@Uprev
Cipher
Osiris Flash
Greddy Twin Turbo 20g
Greddy Oil Cap
HKS Boost Controller
Defi Boost, Water temp, Oil pressure Gauges with Defi Link controller
Carbonetics LSD
Motordyne 5/16 Spacer
Powdercoated Plenum
SGP solid motor mounts
PWR Radiator
DPS Grounding Kit
Silver Powder Coated Plenum
K&N Extreme Flow Filters
Greddy BOV
Fluidampr Harmonic Dampener
Weapon-R Polished Power Steering Tank
Optima Red Top Battery
CJM Twin Fuel Pump Assembly
Impressive list of parts Jay'Z but X02 exhaust?? That kinda suprised me.
  #30
Old 04-27-2010, 11:34 PM
Jay'Z's Avatar
Please lets not derail..
Quick Reply: <<< Jay'Z Greddy TT 20g tuned@Uprev for bigger #'s!! >>>
