turbonetics kit on a 2005 revup
#31
Detonation can be a cause of blown motors but it is not always the cause!!! these motors can bend rods with out det and lift heads/blow head gaskets all with no det running rich is not always the best thing to do it can cause as many problems as it solves. The 7psi is good advice on a TN kit.
my screw clamps hold 20psi
I rather run a little rich than run lean...
#33
Congrats on your install, i have my tn kit on its way right now. Did you diy? I'm thinking about installing myself. I have an 06' revup and am hoping i don't have those fitment issues. I know i have to shim the engine mount in order for certain pipes to clear. Anyone have experience with 06? I heard our engines are a bit lower than the other years, which is why the pipes don't fit well. Tuning your engine by sending in ecu or tuning yourself? I'm interseted in knowing what i can and can't do on my own.
#35
#37
Ya I heard uprev is good by jsprinkle too. I'm deciding between that and aem fic piggyback. With the wire harness it's about 1000 including the tune. I hear the utec is old school. But it might be the sales pitch. I know gtm does uprev tuning but they seem too busy to give a crap. I tried calling them twice about a turbo installation and never received a call back. That's why I decided to do it myself next week.
#39
Issues that im aware of - a/c line melting, ic piping fitment, and some of the turbos in the older kits failing. Anyone else have anything else to add to list? i ask because im halfway done installing my kit and i want to try and address issues before i finish and bolt everything down. also of note, i hear the reflash isnt reliable, which isnt an issue for me cause it doesnt work with 06 anyways and im getting a piggyback or osiris. Thanks for any input.
#42
As for the a/c lines, have then double wrapped with heat wrap or move them all together. The line that runs by the downpipe and under the turbo will be ones I speak of.
as for the tune, I would recommed UpRev. My tuner uses it and the Utec but found that the UpRev to be more user friendly, not to mention without the two computers fighting for control (as with a piggyback) I gained more power and torque and find it to better tune as for power delivery...
#44
I wouldnt!!! I would go with the garrett upgrade that i did...I have had such reilability and I have drove the **** out of it over the summer...
Here are some vids...Check them out!
https://g35driver.com/forums/ohio-g-...enia-ohio.html
#45
