Something different
Old 09-20-2010 | 03:02 PM
CrazyG's Avatar
Something different
It was decided to move my thread to the FI section I think it's better suited here. You guys know me as the guy that is trying to go 200mph in 1 mile and keeps failing. I wasn't going to post my new FI setup until I knew it was going to work and make good numbers but what the hell here's some photos.
Garrett gt3071r BB turbo with .82 A/R TiAL Turbine Housing
New stainless steel valves
TiAL MV-R 44mm Wastegate
After trying and trying to fit these turbos in a more conventional location we decided to think outside the box and take advantage of not having a fuel tank this is what we came up with.
Down pipes.
There is a long way to go I will post up more photos and information as it moves ahead.
Old 09-20-2010 | 06:47 PM
superchargedg's Avatar
Its def different and make sure to give updates and your in good hands with Japtrix.
Old 09-20-2010 | 06:54 PM
Sylvan lake V35's Avatar
Nice!! What kind of rods? What is the bore 96mm? Are the valves oversize? What cams? Are the heads stock or do they have some port work.... looks like the castings were cleaned up a bit? What Head gasket are you using? That is all of the questions I have for now oh wait what kind of power were you making previously and what MPH in the mile did you achieve?? I do like the out side the box thinking you guys have done for sure.
Old 09-20-2010 | 08:02 PM
350Z T's Avatar
Oh, I am loving this. Post as many pictures as possible. At first when I saw the S compressor covers I though, where da hell are these going to go, knowing how tight everything is on these cars. Great idea taking the fuel tank out...who needs that anyway.
Old 09-20-2010 | 08:58 PM
RyanK327's Avatar
Wow awesome, nice secure mounting location. Good thinking, can't wait to see more pics.
Old 09-21-2010 | 12:08 AM
GreenGoblin's Avatar
The goblin resurrection
Very cool Mike, I can't wait to see more.
Old 09-21-2010 | 12:30 AM
2004v35's Avatar
more pics please!
Old 09-21-2010 | 01:09 AM
CrazyG's Avatar
What kind of rods? Pauter
What is the bore 96mm? 95.5mm
Are the valves oversize? no
What cams? C2
Are the heads stock or do they have some port work.... looks like the castings were cleaned up a bit? A little porting
What Head gasket are you using? Cosworth
169,175, 182, 191mph so far and the car made around 650rwhp at 20psi may be more at the mile.
Old 09-21-2010 | 04:27 PM
Interesting so are you using a brand new OEM block or putting the 95.5 pistons in a used block? If putting them in a used block do you just ball hone it and drop them in?
I am going to build another engine this winter and I was going to buy a new OEM block and use my cosworth 95.5 pistons. However I have been getting cheap lately and thinking about reusing my stock block and run a ball hone through it, what do you think??
My last build was a 3.8L my next one will be some what similar to yours using the same rods and cams I have over size valves and a little more port work. So it am curious to see your results of course our turbos are different i have the JWT 850bb and tiny intercoolers. I was also thinking about just using stock heads with the larger cams and selling the big valve heads???
Nice to see you are getting close to 200mph My last build goal was 700-750whp (likely 650-700 with my next engine) and then i was going to try and get to the texas mile and see what it would do so it is nice to see your results.
Old 09-22-2010 | 04:00 PM
nyqueenz's Avatar
Sic build bro.. Dual STS stylen..
Old 09-24-2010 | 11:24 AM
rpm06g35's Avatar
Hahahah the KING OF CRAZY!!!! You need to hurrythefk up Im ready to head back down!!!!!!!!Looks good bro and the pictures you send me on the phone never do any justice son!!!!!!!! Talk soon Mike(owner of the old set up hahahahaha)
Old 09-24-2010 | 01:39 PM
Mike you still doing your equal length manifold?
Old 09-24-2010 | 05:51 PM
rpm06g35's Avatar
Nah danny no matter what he did the turbos wouldnt fit. So he's runnig some stillen headers with the ends cut off. Not sure, but hes running a set of collectors and im guessing 3inch back. Really cool and not many have thought of this cause they always have a gas tank hahaha talk soon mike
Old 09-24-2010 | 07:11 PM
CrazyG's Avatar
Danny still runing equal length with some modified stillen headers. How is your coolant issue? I was thinking about it and was wondering if you are running a expansion take.
Old 10-10-2010 | 01:42 AM
Drako's Avatar
Very Nice... any more recent updates Mike?
brarp (07-20-2011)
