over heating Problems (headgaskets)
Old Oct 3, 2010 | 08:06 PM
specialist's Avatar
Angry over heating Problems (headgaskets)
VQ35de motor
I lifted a head
Stock boar
8.8.1 pistons wiseco 95.5mm
Sleeved block darton
apr head bolts (not L19 bolts)
pathfinder cooling mod
Only 2 coolent hoses remove the unnecessary ones
(sorry for spelling)
I want to know if the apr head bolts are good for 600whp? I used cometic. I think i lifted the head. I have the motor our now. just tearing it down. I am thinking of using HKS but i am about this part????
I have been reading ppl are putting a hr gasket instead of DE gasket what is it better for cooling. if you have a DE motor???? Also i have read that people cut certain parts of the block for better cooling. is this proven?
Old Oct 3, 2010 | 09:59 PM
seymore4's Avatar
m56
Yet another sleeved VQ lifting heads.
Just buy the L19's and a good DE head gasket, I'd recommend hks or cosworth and call it good.
Old Oct 4, 2010 | 10:20 AM
specialist's Avatar
i guess it is common for sleved heads to lift without the L19 bolts?????
Old Oct 4, 2010 | 10:37 AM
bigc's Avatar
Wings Nation
post this up over on my350z. you'll get more responses there. along the lines of what seymore posted, most people there seem to go with L19 studs, and either HKS or Cosworth head gaskets. consensus seems to be that Cometic HGs aren't as reliable, and although they may work, the HR HGs are unproven for high power levels.
again, you'll get more definitive answers posting over there.
Old Oct 4, 2010 | 11:15 AM
seymore4's Avatar
m56
its just common for sleeved blocks to lift heads, period.
Old Oct 4, 2010 | 09:03 PM
Sylvan lake V35's Avatar
Until tear down it is hard to say if you lifted a head or if a sleeve dropped. Sleeves often drop due to incorrect installation so unless the sleeves were installed by darton it is possible one dropped slightly. Also for sleeved engines you should be running evans waterless coolant as it goes along way towards preventing head lift.
Old Oct 5, 2010 | 08:32 AM
specialist's Avatar
headgasket is messed up a big fail
going to get head machined and sleeves looked at
Old Oct 5, 2010 | 08:38 AM
WhosUrBuddiee's Avatar
Looks nasty
Old Oct 6, 2010 | 10:26 PM
urban's Avatar
Wow that is messed up.
Old Oct 7, 2010 | 09:50 AM
specialist's Avatar
i just order L19 bolts , hks gaskets i hope this works. I am getting heads/block decked checked out.
Old Oct 9, 2010 | 02:21 AM
neverbonestock's Avatar
what shop did the work ??
Old Oct 9, 2010 | 11:46 AM
Andrei's Avatar
What torque was the head studs torqued to? It's suppose to be around 94 ftlbs and correct sequence. Head lifting and overheating can also be due to incorrect installation of the iron sleeves. The instructions I have to install those iron sleeves are very specific and there are MANY steps to prep the block.
I would leave the block open next time. Block and crankshaft is fine stock for pretty much whatever you want to make.
Probably import parts pro?
Old Oct 9, 2010 | 03:12 PM
nyqueenz's Avatar
HR headgaskets, L19 studs.. shouldn't have this prob anymore.. btw dont do sleeved anymore
Old Oct 12, 2010 | 02:14 PM
specialist's Avatar
R&B automotive is doing the work for me now they are going to fix my problems. They were not the orginal ppl how did my block
They found i need new bearings too so i bought some too get replaced
I heads were torque to 100 pounds
And one have the the order they need to be torqued by becuase i am going to put the heads on this time. Also the cam caps how much torque they will need there are 3 caps on each cam
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
mattdg35
Sep 14, 2015 11:28 AM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
JG_G35
Engine - Intake/Fuel
Sep 7, 2015 09:35 PM
Jnm07
Sep 5, 2015 01:16 AM
