Calling all Vortech Owners
Old Oct 20, 2004 | 10:11 PM
JspecG35's Avatar
I'm interested in running vortech and I have an idea on what I need such as fuel pump, injector, gauges, ecu flash and the actual supercharger kit [img]/w3timages/icons/smile.gif[/img], what else would I need besides headers/exhaust? anything that is a must for the SC install?
Old Oct 21, 2004 | 09:02 AM
booger's Avatar
Re: Calling all Vortech Owners
If you are buying the kit...you will not need a fuel pump or injectors , unless you are up grading .You also will not need a ECU flash unless you want to up your rev limiter
Couldnt afford it when young...gonna play when Im old
Old Oct 21, 2004 | 10:58 AM
GlenRoseFireFighter's Avatar
a.k.a. RANDYS_G
booger's right, and as for exhaust and headers...not nec, but might help...
Wanna see mine?
Old Oct 22, 2004 | 09:57 PM
gspot35's Avatar
If you are adding injectors and a fuel pump, buy the Vortech "Tuner" kit. You will save a bunch of money. The only other thing you should need is fuel/timing management. Get the splitsecond or even Greddy emanage. If you get the split second FTC, make sure you get it with datalogging capabilities. You may want to use a Crawford plenum for increased air to ALL cylinders. Good luck with the project..
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
junon
Sep 5, 2015 10:40 PM
n2fooz
Sep 4, 2015 07:46 PM
