G35 Stroker Build
Old Mar 2, 2012 | 03:01 PM
  #106
broke_as_ajoke's Avatar
Is that a small block V6?
Old Mar 2, 2012 | 03:32 PM
  #107
Footballmania32's Avatar
Thumbs up
Nopppe! Chevy small block! Its merely a optical illusion!
OP, great build man. You really have a professional look to your work. The seats looked fantastic. Any pictures of the interior all installed? I'll be keeping an eye on this thread, best of luck getting it done before ZdayZ!
Old Mar 2, 2012 | 10:22 PM
  #108
wbama387's Avatar
Originally Posted by str8dum1
dang you've been using his tahoe for almost a year? thats a good friend. Prolly want to buy it from his as well as you arent gonna want to DD that G when you are done.
Why wont i want to dd it? I plan on driving it all the time.
Old Mar 2, 2012 | 10:24 PM
  #109
wbama387's Avatar
I need to take pictures because the interior turned out really well. I will try and get some tomorrow.
Old Mar 2, 2012 | 11:02 PM
  #110
ShanesG's Avatar
Nice, epic diy build
Old Mar 12, 2012 | 07:54 PM
  #111
wbama387's Avatar
So my apartment complex made me get the car out and so i had to move it to my friends storage room. Bearings will be here tomorrow so i should have the engine together by wednesday. Here are some pictures of how it sits now and some parts i got today.
Old Mar 23, 2012 | 02:27 PM
  #112
str8dum1's Avatar
all wrapped up? hows the tuning going?
Old Mar 26, 2012 | 02:27 PM
  #113
wbama387's Avatar
I have not made any progress yet. Im hoping to put things together this week. I will keep this updated.
Old Apr 12, 2012 | 04:09 PM
  #114
str8dum1's Avatar
all together?
a touch over a month til Zdayz. Who's doing your tune?
Old Apr 12, 2012 | 04:31 PM
  #115
wbama387's Avatar
The rings should be here tomorrow so the engine will be going together this weekend and hopefully in by next weekend. I am going to have to run it on a break in tune for zday. I was hoping to put it on the dyno at zday but i guess i will have to save that for another year.
Old Apr 15, 2012 | 01:23 PM
  #116
wbama387's Avatar
So i was putting the bottom end together yesterday and i got the crank in and torqued down and everything was ok. I started putting the pistons in and just hand tightening the rods on the crank. Once i had all the pistons in the crank still turned normally but once i started torquing the rods down after each one the crank got harder and harder to turn. By the fourth rod i couldnt spin it at all. I have checked the rod clearances and they are ok .0018. Checked the rod caps to make sure i put them the correct direction and they were all ok. I have plenty of assembly lube. I need help anyone have any suggestions? Thanks.
Old Apr 16, 2012 | 05:34 PM
  #117
wbama387's Avatar
Well i figured out my problem. The chamfer on the stroker crank is larger than the factory so the bearings have to be cut on the edge. Here are some pics from the weekend.
Old Apr 19, 2012 | 02:33 PM
  #118
nadjkovic's Avatar
Absolutely ridiculous build.. hard to believe it took this long, but I do understand. My previous DD was down for two months awaiting my ported and ceramic coated intake manifolds to come back from MAP.. You must be dying to drive that car. Good luck, sub'd!
Old Apr 23, 2012 | 09:30 AM
  #119
rcdash's Avatar
I don't understand how the bearings do not fit if you measured the crank before ordering the bearings??? The chamfering I thought was just to increase lubrication from the oil holes and it takes away material - shouldn't affect bearing clearances, should it?
Old Apr 23, 2012 | 01:20 PM
  #120
wbama387's Avatar
The chamfer is larger than factory so there is less surface for the bearing to ride on. They do this on performance cranks to make them stronger. Acl says on their website that they design their bearings for this but I guess it wasn't enough.
