Nitrous Help
Old Jan 28, 2005 | 12:00 AM
Z2G2004's Avatar
Nitrous Help
I bought a NX Dry Kit.....I was thinking of starting off small with a little 35 shot and moving my way up in time. I also will be getting a MSD window switch. Is there anything else that I would need to run it safely. Also, my car is totally stock...Is that a problem???
Old Feb 1, 2005 | 10:49 PM
tgalvez's Avatar
I dont think a dry kit will work on our cars..
Everyone that I know is running Wet system
Old Feb 1, 2005 | 11:16 PM
pdjafari's Avatar
A dry kit will work on our cars. A local member on my350z.com has a N/X dry kit. I believe they recommend getting the GenX accessory kit with your dry kit to run it safely. I believe it includes a window switch in the package. You will also need a TPS/WOT (throttle position sensor) switch if u got an auto. From what I understand it can be fatal to shift in MM mode with an auto w/o an TPS switch. I would also get a remote bottle opener as well as a bottle warmer. In total, look to spend about 1k, more/less depending on install. O, its also best to get 1 step colder plugs, I believe Iridium or copper, I dont believe you can use platinum plugs.
Old Feb 1, 2005 | 11:17 PM
pdjafari's Avatar
O, I believe the GenX also includes purge which in addition to being used for the track alot of people use to 'be cool'. However, IF in fact you do have a DRY kit, I have also read they are pretty tricky to tune and are not as safe as WET kits and a bit more risky and tedious. Requires injection through injectors and timing may need to be modified. I believe piggyback is also reqd, like Greddy eManage. I personally would go w/ a wet kit...but to each his own.
G35VSHNG37
Sep 10, 2015 01:54 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
SoCalTed
Forced Induction
37
Oct 7, 2004 11:53 AM
jesterev
Forced Induction
12
Apr 23, 2004 10:26 PM
infidsg35
Apr 7, 2004 03:08 AM
