"TM" Vortech Belt Mod - Interest Thread
Old Mar 23, 2015 | 01:45 PM
  #31
Conway_160's Avatar
If you want the real fix you need a radius rod to prevent the braket from flexing. Flexing loosens the belt alowing slip.
Old Mar 23, 2015 | 01:52 PM
  #32
speedk1ng's Avatar
I don't have an issue with belt slippage. Note in my setup the COBB Tuning idler pulley I have in place to increase belt wrap on the jackshaft ribbed belt:
I want the belt tensioner so I don't have to mess with jacking up the car and remove the splash shield from underneath whenever I need to adjust the serpentine belt.
I also want the belt tensioner so I don't over tighten the serpentine belt and wipe out the jackshaft, idler pulley, powersteering pump, and alternator bearings.
Old Mar 23, 2015 | 02:59 PM
  #33
Conway_160's Avatar
How much boost are you running?
Old Mar 23, 2015 | 03:09 PM
  #34
speedk1ng's Avatar
Just 7.5 lbs.....
Old Mar 23, 2015 | 07:38 PM
  #35
Conway_160's Avatar
Originally Posted by speedk1ng
Just 7.5 lbs.....
Once you get to 15+psi you will need something to prevent the bracket from flexing.
Old Mar 24, 2015 | 09:27 AM
  #36
ge35es's Avatar
search ownz me...
what vehicle is that belt tensioner from ?
Old Oct 1, 2015 | 12:32 AM
  #37
TunerMax's Avatar
G35
I'm running my car over 15 PSI with a non-revup belt setup and my TM variable belt mod and I've never experienced blower pulley slip. I'm also running a 3.12" pulley (one size down).
I believe the people who say the bracket flexes and the timrod setup is awesome and all, however, I've never had a problem, and I beat the crap out of my car, the bushings are old as heck and worn out, and I"m pushing a crap ton of boost and RPM's from the blower.
So, there it is. Just my experience, nothing more nothing less.
StreetStandard
Engine-Vendor
117
May 22, 2020 08:21 AM
sick_sixspeed
Jul 21, 2015 01:59 PM
