Vortech jack shaft bearings on '03 g35 quest
Old Jun 22, 2016 | 11:21 AM
ge35es's Avatar
apparently I've overtightened either the serpentine or the cog belt as my jackshaft bearings are "whirring" like crazy.
I've removed the housing/assembly and removed the shaft/bearings.
one spins fine (serpentine side) and the other is rough. Vortech made a huge deal on how the bearings are heated to put them on the shaft etc.
this will cost me over $350., and a 3 week wait, to get the whole assembly from them.
since this is a common problem... im also sourcing other suppliers for the bearings in the Toronto GTA area.
if anyone has gone through this exercise please post
manufacturer and part number.
my machine shop guru will find more than one way to install the bearings on the shaft.
btw removing the jackshaft assembly took a whole 10 min.
Old Jun 24, 2016 | 10:01 AM
ge35es's Avatar
UPDATE...
found them and they were $14 each....
working on the technique to get them on the shaft
Old Aug 13, 2016 | 09:51 AM
g35loving's Avatar
How did you get your jackshaft assembly off? I got the bolt off the jackshaft on the cog side and know the trick to get the bolt off the serpentine belt side but how the hell do you get the the Allen bolts????
Old Sep 24, 2016 | 12:52 PM
ge35es's Avatar
once the cog wheel is off access to the allen bolts is easy
franky2222
Apr 13, 2016 09:38 AM
guzanote
Apr 11, 2016 05:02 PM
Ghappi
Accessories
Apr 1, 2016 08:15 AM
Jay_Rego
Mar 30, 2016 10:33 AM
Popey87
Mar 30, 2016 10:30 AM
