Any one with a ZEX Nitrous can help OR no's about the TPS
Old May 2, 2005 | 01:30 PM
brands306's Avatar
I had my zex hooked up to the tps on the Tbody and can not get it to set,,, Is there a TPS on the peddle side of the car that will work i can get no help it like on one has put nitrous on a g35 or a Z no one seems to know how to program the zex system not even zex
Old May 2, 2005 | 01:40 PM
MrBillMartin's Avatar
socalted has got a zex set up. hes helping me with mine. hes very knowledgable. im not sure if he is using the throttle position sensor that came with the zex set up. i think hes using a seperate window switch. he could tell you about it.
Old May 3, 2005 | 12:58 PM
brands306's Avatar
your using a window switch and a micro switch
Old May 4, 2005 | 12:12 PM
im using this: http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Old May 4, 2005 | 01:34 PM
MeanGene's Avatar
Tps
Brands - I'm using the white wire from the ZEX nitrous management module directly to the factory TPS ( it stays between 4.5 - 5 VDC ). Then I've run the output to my NX Maximizer ( which is an alternative to a window switch like Ted has ). The rest of the ZEX portion of the install went just as their manual says ( programing of the module to WOT & idle, etc ). Not sure if this helps but I'll double check my wiring anyway. Good luck!
Old May 6, 2005 | 11:10 AM
brands306's Avatar
DID you program the car in park because i see on voltage in park later ill try N OR D also you used the green tps off the Tbody right.
G35VSHNG37
Oct 25, 2015 08:43 PM
G35VSHNG37
Sep 10, 2015 01:54 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
D_Nyholm
May 5, 2006 09:38 PM
G35HP
Forced Induction
Dec 30, 2003 05:21 PM
