APS TT System 05 G35 coupe - 420 WHP on 91 0ctane fuel
#32
Originally Posted by GoldSport
Maybe a stupid question but I must ask, considering this was made specifically for the 05' coupe, will it be possible to fit it onto an 05' sedan with no problems?
![Frown](https://g35driver.com/forums/images/smilies/frown.gif)
Pm me if you need help with a dealer.
![Smilie](https://g35driver.com/forums/images/smilies/smile.gif)
Peter
#33
Originally Posted by BIRU
Hi Peter
I was wondering if u could get me a contact number in australia for APS TT for V35 coupe... I have 05 nissan V35 coupe and I am located in Jakarta Indonesia.... I am not sure if G35 coupe share the same system as my car therefor i need information on this aswell
Thanks
Ari
Thanks
Ari
![Cool](https://g35driver.com/forums/images/smilies/cool.gif)
Peter
#34
Originally Posted by VQ35sleeper
very interesting. is there a lot of stress on the engine internals...since it is completely stock other then the tt and exhaust?
If you intend revving the engine over the stock RPM limit then I would recommend installing a better set of forged con rods - other than this the VQ engine has proven to be very durable to date.
For those living in extremely hot environmental conditions (some parts of the US, middle east, Australia, etc, etc) you may want to consider fitting a more efficient cooling radiator if you track the car, a set of colder spark plugs (1 heat range colder) would also be worthwhile.
![Big Grin](https://g35driver.com/forums/images/smilies/biggrin.gif)
Let me know if you have any other questions.
Peter
#35
Originally Posted by brittain
dude, what do you expect Peter to say, "Yes, it is overstressed and will blow at any minute. You'd better stand back." ![Smilie](https://g35driver.com/forums/images/smilies/smile.gif)
APS claims their system is designed to produce up to around 400 WHP on stock internals with complete safety- I dont think 420 would be pushing it that much more.
Recently APS techs conducted some dyno testing in LA and one turbocharged Z car tested read 390 WHP on a load based dyno and the same car on the same day read 425 WHP on a dyno jet inertia dyno, you can see from this why there is so much confusion in the US regarding WHP from any FI car.
Some (like Tuan at GRD in Chicago) have tuned the APS to higher numbers on the stock internals, but Peter will tell you a built bottom end is recommended.
This 500 WHP is really pushing the mechanical boundaries of the stock con rods and I would not like to see any APS customer suffer expensive engine damage from running too much power on stock rods - around 400 WHP is a much safer power level to aim for.
Tuan is running at 505 HP I think with no problems. This is all on the 03-04 engine, but I doubt Peter would say much different for the 05. Just my $.02 cause Im bored at work.
Thanks
Peter
#36
As far as the shifting points go, just a couple of comments. I've noticed from the dyno graphs that a good portion of the torque is made between 3000rpms and 6000rpms, from this I assume that the best rpm to shift at would be around 6000rpms. I've noticed that owners of other turbocharged vehicles do this as well. It seems that there really is not a point in waiting till 6800rpms to shift.
#37
#38
Originally Posted by Kamal34
Great numbers man, congrats. If you did answer my question already than I appologize but at what psi were those numbers accomplised? 420 on 91 octane is great, but wat psi? Thank you very much!
![Stick Out Tongue](https://g35driver.com/forums/images/smilies/tongue.gif)
#42
I guess Peter does not want to answer. You can bet your **** that those numbers where not achieved with the out of box tune. You know I just had to bring that up since APS is always bringing up that this is the most complete kit and does not require tunning. Yet it seems that the numbers they post up like on their website for example, are not on the out of the box tune.
#43
Peter sure found the time to respond to couple of other threads around the same time I posted here, but still no response here. Answer the question Peter.
Here is the other thread he answered.
https://g35driver.com/forums/showthr...799#post580799
#44
You guys need to calm down and wait for Peter to get around to answering the question. I would personally be very very surprised if it was not in the 8.5 psi range. (+/- 0.5). 420 horsepower on a dynapack is not unheard of, especially when you have the new 05 engine with an exhaust-side variable cam in additional to the intake-side variable cam timing. Also, remember that the cams are more aggressive on these cars to sensibly support a flatter torque curve near the top end for the increased redline of 7000. Hence, making 420 hp to me seems a VERY reasonable number given the skill/experience of the APS tuner. In fact, if this was done with test pipes, it is a fairly safe tune.
