My APS TT G35
Old Jul 22, 2005 | 02:45 PM
  #31
rcdash's Avatar
Why do you inject water into the air intake? What is methanot?
Old Jul 22, 2005 | 07:20 PM
  #32
bullseye's Avatar
Injecting atomized water and methanol (not methanot) under hi-pressure cools the intake charge and helps reduce the chance of pre-ignition and/or detonation. This is for F/I applications, as no real benefits accrue to a N/A engine in most cases. As a byproduct of its use, the methanol also keeps the inside of the engine shiny-clean. A lot of folks use windshield washer fluid, as many of these products feature a 50/50 (water/methanol) mix, which is considered a near-ideal ratio for this purpose. Some folks use it to allow for a more aggressive state of tune, and some use it for an extra measure of safety. So, if you are running your twin turbo through the desert, flip a switch to activate your water/methanol injection system... and relax. There's a lot more detail available, but those are the basics.
Old Jul 22, 2005 | 07:22 PM
  #33
g3po's Avatar
FYI ,Lots O good info here:
http://www.aquamist.co.uk/dc/dc.html
AM makes the "Cadillac" of WI systems.
There are many other less expensive alternatives though.
Old Jul 22, 2005 | 10:06 PM
  #34
rcdash's Avatar
Thanks guys! Someone also resurrected a great post about it (I was wondering why my search for "methanot" came up blank!!!).
Old Jul 24, 2005 | 10:09 PM
  #35
marchesano's Avatar
www.g35tt.com
Madelinot, Congrats! My APS TT is 90% installed right now. I didn't have the guts to do it myself. I figured I would let the professionals handle this one. Anyway, did you have any problem with the AC line on the right side? Mine was rubbing a bit, but we bent it slightly to move it out of the way. Have fun, but be safe!
Old Jul 25, 2005 | 11:26 PM
  #36
Madelinot's Avatar
Thanks! Yes, I did have to bend the AC lines quite a bit. Nothing really hard to do and it's not rubbing on anything. Some pictures show how I bent the lines.
Later,
Old Jul 26, 2005 | 01:16 PM
  #37
k@m NYC's Avatar
any dyno #'s yet?
Old Jul 26, 2005 | 01:17 PM
  #38
k@m NYC's Avatar
oh.. and hi everyone.. im new here and shopping around for a g35 coupe... ok enough thread hijacking.
Old Jul 27, 2005 | 04:35 PM
  #39
G-Crazy's Avatar
What do you think your 0-60 is now that you have added your APS TT? Now I know you might have to guess, but estimating that a stock G35 pulls about 5.5 - 5.8 depending on which source you read it from. Just wondering, cuz I am debating on dropping the cash for the additional power. Thanks
Old Aug 1, 2005 | 09:58 AM
  #40
M6_G's Avatar
Congrats on your setup, since I just got the G35 gonna wait till next spring before I start doing any serious mods to her.. Gonna take it slow and break in nicely... Would definitely like to see some dyno, and track numbers
Old Aug 1, 2005 | 10:47 AM
  #41
marchesano's Avatar
www.g35tt.com
Madelinot, what exhaust are you running with the Kit. Right now, I have the EVO II from Greddy and I am getting a awful vibration when backing off the throttle from 3000 -2700. I originally thought something was grinding, but no I have narrowed it down to the Exhaust portion after the straight pipes. Have you encountered any of this? OH, BTW, I am still grinning since I picked up my car.
Old Aug 2, 2005 | 08:59 AM
  #42
panda007's Avatar
congrats!
100 hours of labor, that is insane. i tip my hat off to you, sir.
i have planned to purchase the APS tt kit in about a month or so. so i decided to dig into the install manual to see how sophisticated this install may be. pretty damn insane...
one question, in step 44, the manual informs to cut off a hard plastic line from the quick connector and from the metal line. do you happen to have a picture of how the fuel lines looked after cut and/or after installing the APS fuel line?
thank you in advance.
Old Aug 3, 2005 | 12:11 AM
  #43
bzabodyn's Avatar
ok, it's after 7-25... so where's the dyno results???
we're (or at least I'M) waiting impatiently...
Old Aug 12, 2005 | 07:35 PM
  #44
ghost30's Avatar
Madelinot, did you swap out your clutch and flywheel? Are you driving an 05?
Old Aug 12, 2005 | 11:48 PM
  #45
paranormal's Avatar
where did you get the instal manual?
