Vortech SC and 05' 6MT Sedan
Old Jul 18, 2005 | 11:39 PM
Jeff Flowerday's Avatar
Has anyone found out if the Vortech SC will work with the 05' 6MT sedan?
Infiniti strengthened the internals with the new 05' motor. I have to assume this is a good thing and would make it an even better candidate for SCing.
Thoughts?
Thanks,
Jeff
Old Jul 18, 2005 | 11:53 PM
mikeemaf's Avatar
From what I've read in other posts in the forum I believe you could have put the vortech on the <05 motors without much incident. I'm sure the 05 would be ok, but you always run the chance of bending, breaking something. If I go FI in the future, I will put the vortech on.
Old Jul 19, 2005 | 12:53 PM
Just got a reply from Vortech.
Our kit has been confirmed for the Manual trans 287hp vehicle, but not the 298hp version
I've replied asking if they plan on it or not.
Old Jul 19, 2005 | 01:20 PM
Ok a test vehicle is needed.
We are currently looking for a vehicle in the area to test. Once we have a
vehicle here, we can begin the programming process.
I would but I'm in Canada.
Old Jul 19, 2005 | 01:29 PM
escobar929's Avatar
too bad i'm in SFL or i would be the test monkey
Old Jul 19, 2005 | 01:42 PM
Derzigster's Avatar
I live 2 blocks away from Vortech but unless the are getting CARB approval I have no plans of putting it on my car. I would also like to keep my warranty.
Old Jul 19, 2005 | 03:01 PM
Someone in the other Vortech thread mentioned they just got approval.
Old Jul 21, 2005 | 05:23 PM
Texasscout's Avatar
Thumbs up Yes It Will!
Just got this back from Vortec!
Chris Matye [cmatye@vortechsuperchargers.com]
Our kit will fit your vehicle. Listed below are part numbers and retail pricing.
4NZ218-050SQ 2005 Infiniti G35 Satin Finish-$5495.95
4NZ218-058SQ 2005 Infiniti G35 Polished finish-$5895.95
-----Original Message-----
Sent: Thursday, July 21, 2005 11:01 AM
To: info@vortechsuperchargers.com
Subject: Info please
I have a 2005 Infiniti G35 MT6 Sedan, with “Sport” suspension. Will your G35 SC kit fit my car?
William Albert
Old Jul 21, 2005 | 05:29 PM
escobar929's Avatar
good to know, price seems kinda high though
Old Jul 21, 2005 | 06:03 PM
g8tor20's Avatar
FGC's official flip flopper
Votech just told me they have 2005 G35 kits...so I guess they are available.
Old Jul 21, 2005 | 06:08 PM
Texasscout's Avatar
That's RETAIL price, your mileage may vary....
Old Jul 21, 2005 | 09:35 PM
He just told me 4 days ago that they haven't tuned it for the the 298hp engine yet, waiting on a donor car. They do have one for the 05' 280hp AT though.
Old Jul 23, 2005 | 09:10 AM
neffster's Avatar
Weird, the post above clearly states...
William Albert
Maybe another call into Vortec would be prudent. G8tor20 called them and they told him there is DEFINITELY a Vortec ready for the 2005 5AT's. Could this be because they have the same engine as the 2004's?
Old Jul 23, 2005 | 12:59 PM
Luke enas's Avatar
i got a responce a few weeks back and this is what you are looking for
On March 21,2005 Vortech Engineering released a supercharger kit for the
2005 Infiniti G35.
Release Notes:
. This kit is identical to the 04 G35 kit except for the Split Second
program and a small amount of additional hardware.
Summary:
Allows retention of all vehicle accessories.
Installation time is 8-12 hours.
CARB EO is forthcoming.
Included components:
. V2 CCW rotation sc-trim SQ supercharger uses 6-rib 3.33" pulley and
secondary cog drive (32T/28T) produces ~8 psi at 6500 rpm.
. Charge air cooler assembly (air to air) increases performance and
reliability of supercharger system and includes:
a) Welded aluminum charge air cooler core assembly with cast end tanks.
b) Aluminum discharge tubes.
c) Maxflow race compressor blow-off valve, silicone sleeves and stainless
steel hose clamps.
. Piggy-back ignition timing control computer.
. Fuel system upgrade includes an inline fuel pump assembly and FMU.
. Supercharger drive system includes all necessary belts and pulleys.
. Billet mounting plate assembly mounts the supercharger.
. Re-useable high flow air cleaner.
. Oil drain and oil feed assemblies allow for maintenance free operation.
Part numbers:
Flywheel horsepower: stock-- (HP/TQ) 280/270;
supercharged-- (HP/TQ) 404/350 [estimated based on % increase @ wheels]
Kits can be shipped to order.
Pricing will be the same as previous model years.
Old Jul 23, 2005 | 01:10 PM
2005 Infiniti G35.
Release Notes:
Summary:
steel hose clamps.
Part numbers:
Yah, this says they released it for the auto, it does not mention the 298hp 6MT engine.
These specs are the auto...
tiguy99
Mar 1, 2016 11:42 AM
derres
Aug 28, 2015 03:27 PM
Tukeeg35
Engine - Intake/Fuel
Aug 21, 2015 04:19 PM
TheKnite
Aug 14, 2015 07:59 PM
