G35 FI numbers?
Old Jul 25, 2005 | 01:36 PM
tony's Avatar
G35 FI numbers?
I hope this isnt a repost but I was wondering what the turbocharged/supercharged G35's are putting to the ground.. I'll start
1.tony 406whp 389lbtq
Old Jul 25, 2005 | 01:51 PM
GXCLUSIV's Avatar
Would be nice to know, what FI kit installed, and if on stock or built motor, what other mods installed and at what psi.
Old Jul 25, 2005 | 02:22 PM
tony's Avatar
good point
1. tony 406whp 389lbtq @ 10psi w/ 4000 HARD miles on a stock block.. APS Twin Turbo kit. other mods: Water injection (very effective in keeping temperatures down) test pipes and nismo exhast.
Old Jul 25, 2005 | 02:28 PM
mc2's Avatar
mc2
do you think we could post 1/4 mile times as well?
Old Jul 25, 2005 | 03:05 PM
tony's Avatar
lol ok
1. 1. tony 406whp 389lbtq @ 10psi w/ 4000 HARD miles on a stock block.. APS Twin Turbo kit. other mods: Water injection (very effective in keeping temperatures down) test pipes and nismo exhast. 12.9 @ 111mph but I know the car is capable of low 12's high 11's.
Old Jul 25, 2005 | 03:17 PM
GlenRoseFireFighter's Avatar
a.k.a. RANDYS_G
2. Randys_G 388whp 328lbtq (untuned on current 93 octane) Vortech SC on stock 8psi, 11,000 HARD miles with 2 road track days in 100+ temp and over 150 passes down the 1/4 mile track...other mods: Injen exhaust, Kinetix Cats...best 1/4 mile: 13.2 @ 109mph - 2.222 60ft...I know this car could do mid 12's with a new Texas tune and will def be over 400whp once that's complete...stock internals
Old Jul 25, 2005 | 08:14 PM
booger's Avatar
built motor...9 to 1 pistons . T-trim vortech , cams , return fuel system , 550 injectors...13.5psi [ for now ] 455whp and 345trq . Havent been back to the track
Old Jul 26, 2005 | 12:32 PM
a.k.a. RANDYS_G
3. Booger built motor...9 to 1 pistons . T-trim vortech , cams , return fuel system , 550 injectors...13.5psi [ for now ] 455whp and 345trq . Havent been back to the track
Old Aug 4, 2005 | 02:26 PM
Madelinot's Avatar
4. Madelinot 342rwhp, 367lbtq at 7.5psi. APS TT, 93 octane maps, completely stock (including cats and exhaust) except for the Crawford Plenum.
Old Aug 4, 2005 | 04:35 PM
narkotic's Avatar
You all should post when those TQ numbers are coming on (RPM) 340 lbs of torque does you no good at 6.6krpms
Old Aug 4, 2005 | 07:05 PM
Pwoz's Avatar
Madelinot, is that a typo or are you really only making 342rwhp with the APS TT... just seems really low for that kit.
Old Aug 4, 2005 | 07:15 PM
narkotic's Avatar
Pwoz - he has the stock exhaust and cats. Completely normal.
Old Aug 4, 2005 | 09:54 PM
GurgenPB's Avatar
5. Gurgen 428rahp, 460ratq at 11.8 psi, however, it made 395rahp, 405ratq at 9 psi, so the restictive exaust and some other parts are really holding me back. PE TT, sleeved/decked block. Stock cams/valves. Test pipesm, Motordyne 1/2' spacer. Stillen exhaust. PE 510cc injectors, ecu reflash (custom developed).
Old Aug 8, 2005 | 08:13 AM
Madelinot's Avatar
Yes, with stock exhaust. There was some kind of problems with the dyno however since the car only boosted up to 6.9 psi on the dyno, while I usually get 7.9 on the streets. I also had it retuned last week and it feels a bit stronger now. It should be around 380whp. An exhaust should give me an additional 20whp. I think it's in the ballpark....
Later,
Old Aug 8, 2005 | 11:48 AM
a.k.a. RANDYS_G
Hey Nark, where are your numbers?
