How do I raise my idle
If your build date is post 10/2003 you can't raise your idle with a simple Consult II bump. You can however advance your timing by +2 degrees. This will initially raise your idle rpms by ~100rpm. Unfortunately your idle rpms will soon revert back to where they were before the timing advance but your timing will still be advanced. (At least this was my personal experience).
JWT may sell a kit to help with the idle. Check their website. I know they have something for the guys with the 10/2003 or later build dates who buy their cams...
Do some research on mail order tuning. I've read quite a few threads where there have been many unhappy TechnoSquare customers. Shouldn't be hard to find, especially if you search on my350z.com.
Originally Posted by Mr_pharmD
what does it sound like??
I think I'm going to drive over to TechnoSquare and see whats up.
hey rudeboy, for the vortech sc, did you have to modify the kit to fit your car? I am in the process of buying one but the dealer says it's only for MT and I might have to modify the kit to make it work on an AT. Is this true?? Also, is 4250 shipped for satin a good deal?
Originally Posted by Rudeboy
like a slight chirp or something every few seconds ..
So does the chirp go away or only when the engine is cold?
