i need a baseline map for the vortech splitsecond box ASAP!
Old Sep 13, 2005 | 01:54 PM
booger's Avatar
Originally Posted by googe
neffster:
Do you have a dynojet near by?
yes, the shop charges $75 for 2 pulls...i was thinking of heading over there just to compare numbers but im not sure that its worth paying for
What was your boost at when you hit 300rwhp?
it was around 5.8 psi i believe. the dyno was 3000ft above sea level, which is about a 1.5 psi difference. so effectively 7 and a half psi or so?
Can you get your belt any tighter?
nope, it was JUST tightened prior to tuning and going on the dyno. shes tight!
Did you have the stock wheels on?
yes, stock 03 18" wheels
with 5.8psi...300whp...yup...thats normal...as far as timing goes ...there is some room to put back a little timing . Find a tuner with R4 know how and that has tuned it before .
Old Sep 13, 2005 | 01:57 PM
googe's Avatar
well i was thinking about that, then i realized the dyno would have applied the SAE correction factors for elevation, and the 300whp should reflect the numbers as if they were at sea level, right? so it would be 300whp at 7.5 psi i think
Old Sep 19, 2005 | 02:56 PM
Stg2_SRT4's Avatar
Hey Googe, i was trying to PM you but for some reason i cant send PM's. Would you mind Emailing me or IMing me on AIM? my email addy is oogotbagsoo@aol.com and my AIM is oogotbagsoo.
Thanks dude.
suby01
Not G35 Related
May 25, 2016 03:07 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
prinny
Nov 22, 2015 11:07 PM
Learned Hand
Oct 1, 2015 09:02 AM
