Officially NA (Vortech Drama Continues)...need help!!
on
Ok guys. I drove to Orlando and had a reputable shop take a look at my Vortech. The bearings inside the blower is the culprit of the awful rattle. I will have to return after the thanksgiving break to have them take it off and ship it to Vortech.
In the meantime, I took off the cog belt and am running NA. I have some new questions:
First off...simultaneously, I installed an Injen TD exhaust to replace the stock one. My car feels REALLLLLLLLLy slow. I mean....like taking 8+ seconds to run to 60mph. I dont hear an exhaust leak. WTF. The serpitine belt of the Vortech still spins and whines. Would this robbing of some horespower and adding a TD exhaust make my car bog down like that??? I would love to hear from you guys that have gone NA temp. by taking the cog off. DOes it bog you down worse than a stock G?
Secondly...even running NA, my EGTs get up to 1400-1500 on hard runs. Also...my a/f hits all the way down to 11.0. Should a NA car be hitting 11.0 and 1400-1500 egt at 6200 rpms?
Any help would be great guys. My main concern is how bogged down my car is. I hope it is the combination of the s/c (not the blower) still spinning and the new TD exhaust. Does the fact that my CAI is now a like a 7 foot tube (I guess it has to go through all that Vortech piping still).
Please help. I think something may be wrong.
on
Might be a good idea to disconnect a section of IC pipe and put a piece of foam or something over it [ filter ] . You may not be getting enough air thru the BOV . I did mine on the section of pipe right before the MAF sensor . The pipe that has the 45 Degree bend . Turn it out twards the fender and put a piece of foam filter over it . You'll breath much better
Moderator
on
FYI guys, a guy in the GSQUAD had the same issue. The bearings in the Vortech went while on the dyno. An insider at Vortech mentioned there was a bad batch of blowers that went out. They know the serial numbers to the bad sequence, but still try to get around giving youa new blower. If you push hard enough, they will give you a new blower as opposed to rebuilding the bad unit.
Also, be thankful you didn't get chunks of metal in your oil pan from the blower cuz that would be an easy way to to make the VQ go boom. Anyway, just wanted to give you guys the heads up and keep an ear out for ecessive noise from the blower.
on
on
I dont think so...sound seems to go away above 1100 rpms. Then again...my the engine noise may cover it up at that point. But my guess is that it goes way at about 1100.
I took the car to Next Level Proformance in Orlando and they took a stethoscope looking thing to it and knew exactly what it was. The bearings inside the blower itself. So...I go back in a few weeks to remove it and send it back
See....that is the thing I don't get.....
Seems like if it was bad bearings, it would be making a hell of a racket at upper rpm's.
Mine makes all kinds of wierd rattleing noises at idle....but only whines like a turbine as speed increases.
Ours came out of the same batch.....pm me with your serial # if you would.
Moderator
on
I'll try n get whatever info I can. I don't my buddy will know what batch of serial numbers have problems, but I'll ask. I believe his noise was like realllllllllllllllllly loud. Loud enough to cause enough concern to shut it down on the dyno. I think he was only able to get about 4lbs of boost which is why he made so lil power....which is why he has the shop check everything out.
on
