NEW VORTECH set up!
Old Jan 11, 2006 | 09:42 PM
booger's Avatar
Originally Posted by MechEE
I doubt the IC is the reason for the slippage. I haven't lookd at its specs, but I doubt it's fine at 6 psi and a problem at 13. It's just the increased output pressure that the blower has the maintain, coupled with a smaller belt coverage area on the pulley. Also, if the smaller pulley isn't anodized, it will be more prone to slip.
Just relating what has happened to me . I can tell you the preasure between the IC and the blower is much greater than what you see at the plenum . As far as the pulleys being anodized . And old V8 SC trick to get better grip on the pulley was to sand blast the anodize off so the belt would grip better on the pulley . The belt would get used up faster though
Old Jan 11, 2006 | 09:58 PM
MechEE's Avatar
The pressure is definitely higher pre-IC (air is hotter, and it's before the intercooler "restriction"). BUT I am only saying that it's not the fact that the IC is there that is making the belt slip... remove the IC and I bet it still slips.
Regarding the pulley, I ran both raw and anodized pullies on my setup, and the belt stuck much better to the anodized pullies (could have been a fluke, who knows). But one this is for sure, raw pullies would get eaten down and eat the belt at the same time!
Old Jan 11, 2006 | 11:10 PM
MeanGene's Avatar
Thumbs up Ditto!
Booger -03 G35 AT5
Urban - 04 G35 AT5
Mean Gene - 03 G35 AT5
Old Jan 11, 2006 | 11:22 PM
booger's Avatar
Thats what I was trying to say . If you upgrade the IC and pipe out of the IC you will lessen the restriction that the blower has to over come . I may not be able to get a higher psi , but with less restriction it will flow much better and produce more hp
Old Jan 11, 2006 | 11:24 PM
booger's Avatar
And if Vortech will make this new set up , so the belt will slip less or not at all . All of us will benefit from it . Keep the names coming
Old Jan 12, 2006 | 05:36 PM
MechEE's Avatar
If you can lower the IC "restriction", you should see higher pressures in the manifold.
Old Jan 12, 2006 | 06:25 PM
booger's Avatar
Yes Im pretty sure I will .The belt will still slip at the same exact psi , but should see higher psi at the plenum . Before , I was at 13.5 in the plenum and who knows what it was at the blower .18 , 20 , 26 PSI ??? . With a bigger , less restrictive IC . The psi in the plenum should be higher , but the psi at the blower will still be the same when the belts slips
Old Jan 12, 2006 | 06:26 PM
booger's Avatar
Booger -03 G35 AT5
Urban - 04 G35 AT5
Old Jan 14, 2006 | 12:44 PM
UMG35's Avatar
Booger -03 G35 AT5
Urban - 04 G35 AT5
UMG35 - 04 G35 6sp
Old Jan 17, 2006 | 07:20 PM
booger's Avatar
Ttt
Old Jan 30, 2006 | 12:55 PM
BeerViper's Avatar
Booger -03 G35 AT5
Urban - 04 G35 AT5
UMG35 - 04 G35 6sp
BeerViper - 04 G35c 6MT
Old Jan 30, 2006 | 01:16 PM
kzanard's Avatar
Booger -03 G35 AT5
Urban - 04 G35 AT5
UMG35 - 04 G35 6sp
kzanard - 04 G35c 6mt
Old Jan 30, 2006 | 02:48 PM
booger's Avatar
Keep it coming guys....Just waiting for word from DSport on what Vortech did for them
Old Feb 1, 2006 | 12:20 PM
GlenRoseFireFighter's Avatar
a.k.a. RANDYS_G
Originally Posted by BeerViper
Booger -03 G35 AT5
Urban - 04 G35 AT5
UMG35 - 04 G35 6sp
Nice to see you;re getting into the upgrades already...
Old Feb 22, 2006 | 07:07 PM
  #30
BeerViper's Avatar
Hey booger ... any news about this?
