NEW VORTECH set up!
Old Jun 9, 2006 | 04:31 PM
  #61
sentry65's Avatar
I didn't do it, my shop did, I think they somehow used a hole where a bolt already was and used a longer bolt but I actually don't know.
He had to use a 10mm bolt though because at first he tried using a 8mm bolt - maybe 8mm is the stock bolt size? and bored it out to fit a 10mm bolt or something? I'm really not sure I remember, but the 8mm bolt setup didn't cut it and the pulley actually started wiggling off while on the dyno until it pretty much came off and was hanging at a 45 degree angle and causing sparks
he used some loktite on the 10mm bolt
my car had some slight slippage up top with the 3.12 pulley before using this extra pulley. Now with the 2.87 pulley even there's no slip
the only issue I'm kinda paranoid about right now is the belt is just barely clearing the cam sprocket or timing chain or whatever that part sticking thru the vortech plate. It clears it by about 1mm when the engine is cold, but when hot it's right on it, though I haven't seen any severe rub marks yet. I'm going to still have that new pulley brought out an extra mm with a spacer or something
Old Jun 9, 2006 | 04:41 PM
  #62
BeerViper's Avatar
Yikes, sparks on a dyno doesn't sound too good! Well thanks for the info, even though it doesn't sound like a DIY job it is definitely an option.
I'm still in the 3.33 pulley club until I can find some disposable cash to upgrade my injectors/fuel pump and go with the 3.12!
Old Jun 10, 2006 | 01:13 AM
  #63
MeanGene's Avatar
Unhappy Don't Ask!!
Randy - No, I haven't forgotten about that ride I promised ya BUT John & I made a tactical mistake which set the project back about 6 weeks!
I/we decided to wait on ARP to release those 7/16" L19 head studs so that we'd feel more comfortable about pushing the Vortech up into the 20#+ boost range. Of course, as with any new product there were delays & just about the time Sharif said the first shipment was due to go out John called me & asked why we didn't just use some ARP 1/2" studs instead?? Yea, I know - where was THIS idea 6 weeks earlier?? We just BOTH had brain farts, I suppose. He emailed me earlier today & said that the engine was due to be assembled starting next week so I'm hopeful that I'll have the car by early-mid July. Not gonna rush John - we still haven't decided what to do about the tranny concerns. We're leaning toward using a 4L80E - any thoughts here, Randy?
John has already done the DSS axles & Quaife so the weak link appears to be the A/T since the motor should be bulletproof - well, ya ain't seen me drive!!
I'll keep everyone in the loop because I miss my baby!! Told John that I wanted to fly back over & have him push me around the block to see if it still handled good!!!!
Gene
Originally Posted by GlenRoseFireFighter
what ever happen with yours, Gene? I never heard from you.
Old Jun 13, 2006 | 04:37 PM
  #64
GlenRoseFireFighter's Avatar
a.k.a. RANDYS_G
Gene
Wow, a 4L80E...you'd be the first to throw a bowtie tranny on a G. SWEET! I can't wait! Call me when you're all finished...310.818.1875. Take care bro.
Old Jun 16, 2006 | 12:45 PM
  #65
MeanGene's Avatar
Lightbulb Plan B
Randy - John & I both contacted Tim with Speed Force Racing & for about the same price ( $4k ) we can go either way. There'll be less fabricating with the Nissan tranny so I'm leaning that way. I kinda feel like I'm already stepping into unchartered territory with pushing a Vortech'ed motor as far as John & I want to ( 700 hp + nitrous ) so I might play it safe(er) by staying with the import tranny. Still gonna try to integrate that paddle shift system John found!!
Gene
Old Jun 16, 2006 | 03:22 PM
  #66
a.k.a. RANDYS_G
Gene
paddle shift system! SWEET!
Old Jun 16, 2006 | 06:37 PM
  #67
booger's Avatar
Gene
Gene
Have you fabricated an all cog belt system ? I expect DSport to come out with the one Vortech made for them soon .
And if your sticking with the Stock tranny . WHat plans do you have to build it ? If you dont mind me asking
Old Jun 18, 2006 | 06:25 AM
  #68
MeanGene's Avatar
Smile Belt System
Originally Posted by booger
Gene
Bill - John wants to wait for the DSport system but U know him - if it's not up to his specs then he'll custom fabricate one for me!! As U well know ( since U've been there first! ), anything in the double digit boost range lends itself to belt slippage ( even with our larger FMIC's ). so we're stepping off the deep end here with 20#+ of boost. Been keeping track of your own posts as well so any info-sharing U'd care to do will be greatly appreciated.
As for the tranny, Tim @ SFR says that they have their own clutch packs for our trannies so they install those plus redo the valve body for firmer shifts & finally mod the T/C for whatever stall U specify. John & I have decided that 3k rpms would allow the motor to flash-stall into the lower end of it's powerband & since I'd already had Level 10 restall mine to that stall speed 2 years ago I can save a little $$ by going with it as it is. The L10 V/B mod, however, doesn't shift as firmly as I'd like so Tim said they can re-mod it into SFR's specs. The cost is roughly $3750 ( & the 4L80E setup was $4200 ) so U can see it's a wash price-wise.
Here's Tim's reply email to John & myself:
Note the power level John's throwing around!!!!
Gene
-----Original Message-----
Sent: Thursday, June 15, 2006 7:46 PM
To: john@rabbidperformance.com
Subject: RE: Tranny Modifications
We put in new clutch packs with different clearances.Modify the valve body and do the convertor.The valvebody is responsible for the shifting firmness.It does help quite a bit.We can set up the stall of the convertor the way you want.
Tim
-----Original message-----
Date: Thu, 15 Jun 2006 1525 -0700
To: "'Info'" info@speedforceracing.com
Can you guys tell me what you do to these trannies and do you have any means of adjusting shift points and firmness?
<10.0pt;font-family:tahoma'>-----Original Message-----
Sent: Wednesday, June 14, 20069:29 PM
Subject: Re: Tranny Modifications
Yes we can help you. We can do the tranny and TC for $3750
Tim
Date: Wed, 14 Jun 2006 1815 -0700
To: Info@SpeedForceRacing.com
Subject: Tranny Modifications
Word has it you guys have a transmission upgrade available forthe Nissan 5AT for 350z/G35 that is capable of withstanding 1000+HP. I have a 5AT customer that we are going well beyond the limitations of the factory trans to the tune of 700 w/100 shot. Looking to do complete swap for GM L80e over drivetranny with stand alone TCM but that’s only if no one has anything to beef up the factory tranny.
Thanks
John Isbell
Old Jun 18, 2006 | 08:33 AM
  #69
booger's Avatar
I have to ask Dereck from DSport what clearance is needed in front of the motor to bolt on the cog pulley to the crank shaft . The AT5 radiator may not allow for it . If thats the case , a new radiator and remote tranny cooler will have to be fitted first .
Old Dec 26, 2006 | 12:29 PM
  #70
a.k.a. RANDYS_G
Gene...status?
Old Dec 26, 2006 | 03:56 PM
  #71
urban's Avatar
As far as I know Gene sold his car recently to someone called Mike.
Old Dec 27, 2006 | 06:22 PM
  #72
booger's Avatar
yes thats what I thought also
Old Dec 27, 2006 | 07:06 PM
  #73
dreamweaver's Avatar
hmm i just got my 05 rev up vortech kit in today... I know the supercharger has a cog belt... its kinds greenish colored.. hmmm should i do this extra pulley? where did you get it. id like to do that seems like it would not hurt to add it
Old Dec 27, 2006 | 07:29 PM
  #74
molidor01's Avatar
molidor01-03 G35 AT5
Old Dec 28, 2006 | 10:19 AM
  #75
a.k.a. RANDYS_G
first I'm hearing of it...oh well...wasn't meant to be.
