Exhaust Gas Temperatures (EGT)
So after searching 8 pages of threads with these words I found two things..........jack & $H1T!
Needless to say there was zero information on what temperatures should be of concern to you. Yes I realize that the temps you see are going vary widely depending on where you've got your sensor mounted.
So for those running exhaust gas temperature gauges;
1. What kind of temperatures are you seeing with your FI setup (& where is your EGT sensor mounted)?
2. At what point would you get worried that the temperatures are too high?
Your help is much appreciated.
Later,
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
Rhinos7777
Sep 6, 2015 05:36 PM
