Stillen SC self install, anyone done it?
Old Feb 2, 2006 | 09:44 AM
roneski's Avatar
Devil's Advocate
Yes I did a search and didn't find much but several people like to call the Stillen SC plug and play.
I have average mechanical ability and am an excellent (electronic) technician, and I'm tempted to install one on my G myself. I was wondering if anyone else has tried it. Any issues?
Old Feb 2, 2006 | 11:14 AM
superchargedg's Avatar
Thumbs up
i did it,it took about 7 hours and the biggest thing i can say is read the instructions while looking at the engine,then reread them again.the only problem i had was soldering the 2 cam sensors and the 1 crank sensor(very little room to work with do not use the supplied crimps).after every thing was buttoned up i had a gas leak at the 7th injector(pinched the damn oring)which was a real pita once everything is together all in all the instructions are very good and what a blast to drive you will love the tourqe it puts out.good luck with youre install.
Old Feb 2, 2006 | 01:34 PM
caelric's Avatar
The only thing I would be worried about is the warranty. I know Stillen warranties both the SC itself, and the engine as well. However, do they still give the same warranty if it is not installed by an authorized dealer?
Dave
Old Feb 2, 2006 | 01:40 PM
Chad@infinitispecialists's Avatar
i would like to know the same thing to the comment above
Old Feb 2, 2006 | 02:41 PM
sukhi's Avatar
I installed the SC myself. It took me quite a while longer than the 12 hours that the instructions say it will. I ran into a few problems: Had a hard time with the main belt, one of the o-rings on the fuel rail tore so i had to go get a new one, and I had to trim my nismo bumper to get it to fit around the intercooler.
The warranty will be void unless it is installed by a licensed shop, however I don't think the warranty is as good as it sounds and its only valid in a stage 2 setup. I think most people will jump or will want to jump to stage 3 and even stage 4 if it proves to be a reliable upgrade.
Old Feb 2, 2006 | 03:25 PM
caelric's Avatar
Kind of what i thought; although I don't klnow about the warranty not being as good as it sounds, I figured it would be void if self installed.
Anyways, it's moot; I like the Stillen SC for it's driveability, but I can't stand the ugly hood.
Dave
k67p67
Engine - Power Adders
Aug 29, 2015 08:19 PM
Albanian122
Aug 27, 2015 11:02 PM
Spartan268
Aug 20, 2015 09:14 PM
Team STILLEN
Aug 10, 2015 08:17 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
