FI Help for an FI newbie
Old Feb 21, 2006 | 09:18 PM
Gdup's Avatar
sooo i finally decided to go FI. I have an 04.5 infiniti AT coupe. So heres the questions...which kit is the best to go with when i have auto transmission , as in safest? Ive heard not to go with vortech, and i dont want to deal with a valve body upgrade and such.... i was thinkin bout gettin the turbonetics, but as i said, i dont know to much. Help!
thanks
Old Feb 21, 2006 | 10:33 PM
booger's Avatar
what makes you think the VB upgrade is only needed for the Vortech ? If you dont want to upgrade the tranny...a SC is more suited than a turbo . Less stress on the tranny in the lower rpm's . I have a Vortech SC on my AT5 with no problems at all . It may not shift in auto mode at WOT untill you bounce off the rev limiter . Raising the rev limiter to 7,200rpm solves that problem .
Old Feb 22, 2006 | 01:09 PM
superchargedg's Avatar
use the search it will answer almost any question you might have.also i run the stillen stage 2 with no problems and no tranny mods.have over 15000 miles so far.good luck.
Old Feb 22, 2006 | 04:35 PM
GCRAZY's Avatar
If you don't want to touch the tranny get a SC.
Vortech and Stillen stage II are a good option but if you want a turbo, get a ST and leave it a stock boost.
I have a Greddy TT at 8psi and no tranny problems.
Tasso-
Old Feb 22, 2006 | 04:44 PM
BeerViper's Avatar
Vortech has been getting a lot of bad press around here with g8tor20's ordeal. I am driving a Vortech blown G (albeit a 6MT tranny) that has over 16k miles on the blower setup. There are no problems and no signs of problems with the supercharger or anything else for that matter.
Additionally, the dyno numbers you see (366/300) are at 5.7psi as reported by the Split Second piggyback ECU. The low boost is attributed to the free flowing exhaust yet the numbers are still respectable.
Old Feb 22, 2006 | 06:07 PM
Gdup's Avatar
ok so vortech it is...( i really hate that stillen hood)... ok so next up, im still being told that even if i get the vortech, i should still get hte valve body upgrade..and also, what else do i need besides the kit? and where is the cheapest place to get the vortech?
Old Feb 22, 2006 | 07:14 PM
BeerViper's Avatar
See booger's post ... he doesn't have the VB upgrade on his and he's putting down very respectable Vortech numbers. You really don't need anything else with the Vortech kit but there are always recommendations like tranny cooler, oil cooler, etc.
EverythingG35.com has the kit for $4700...
http://www.g35parts.com/9083/osc/pro...roducts_id=133
Old Feb 22, 2006 | 07:22 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
There's a guy in the classifieds right now selling his polished vortech BRAND NEW with a set of UD pulleys for $4100+shipping. If your serious about the vortech i'd hop on that deal right now.
-GP-
Old Feb 22, 2006 | 07:26 PM
nate4598's Avatar
I heard that neither Vortech (less 8psi) nor Stillen would need VB upgrade but it would be nicer if you get the VB upgraded
Fox843
Nov 7, 2015 05:43 PM
Hawk196
Sep 22, 2015 02:51 PM
njkud
Interior
Mar 17, 2003 11:20 AM
