f/i and smog tests....
Old Mar 5, 2006 | 07:32 PM
klg35's Avatar
for all you f/i folks, what do you do when it's time for a smog check, especially catless kits.......going the f/i route soon and just wondering about that......pm will do nicely.. thanks.
Old Mar 5, 2006 | 09:49 PM
MechEE's Avatar
Yeah, it's called failing inspection. And catless you'll fail at the pipe too. It's a rough life in Cali with such mods and strict fines for crooked smog shops. The best thing you can do for passing inspection is to get a CARB exemption certificate from a CARB-exempt kit, either by owning the kit or being friends with someone who owns such a kit.
Old Mar 6, 2006 | 09:22 AM
GaryEvans's Avatar
Carb sticker not it still has the past the tests in use at that station (scan or tailpipe) and visual inspection. It will fail if it doesn't past the tests and/or they detect that the cats are gone. The stickers value is to show that the turbo kit has passed Carb which most states accept as prove that it is a legal mod. Without the carb approval it could pass the emissions tests but fail because they see a turbo has been installed.
Old Mar 6, 2006 | 05:23 PM
klg35's Avatar
ok, so need to find friends with same f/i setup.........that will be VERY difficult as i'll need to find a black 6mt sedan w/single turbo setup in so-cal area........once they pop the hood, t60=hello!........guess i got to go underground......
Old Mar 6, 2006 | 05:39 PM
luongdmd's Avatar
kinda SOL......... lucky for me i dont have to smog for another 4 years.... then i'll tackle this problem then
Old Mar 6, 2006 | 06:10 PM
DrewTheSuit's Avatar
curious as to how everything works with people living in cali but have out of state plates/registration
Old Mar 6, 2006 | 06:15 PM
luongdmd's Avatar
if you have out of state plates.... you are held to that states law..... the only thing you need to worry about is when you need to renew your plates, and they require you to have it smogged, you need to take it back to your state or you can choose to have it smogged in whichever state you're in... but the catch is you need to register your car in that state then, and then you are subject to that states law........
Old Mar 6, 2006 | 06:16 PM
GaryEvans's Avatar
I've been surprised at the number of non-carb kits being installed when most all locations now have emisions testing. When the test dates roll around it isn't going to be pretty. Even if you sell the car before its test date your going to be liable for selling a non-compliant vehicle if the new owner decides to file suit after they find the plates cannot be renewed. Some states even require a formal pre-sale disclosure to the buyer that the vehicle is only usable for off road use. Once you fail the test your in the state records and your options are few.
lag35driver
Northern California
Sep 17, 2015 12:32 PM
g4ian
Forced Induction
Nov 19, 2004 09:19 PM
Dsskyline
13
Aug 9, 2004 08:43 AM
Msedanman
Intake & Exhaust
12
Nov 28, 2003 01:18 PM
