JWT twins on my 5AT by VRT.
Old Jun 16, 2006 | 11:22 AM
  #61
Xman's Avatar
Congrats on the TT! What kind of tranny cooler are you considering? An intercooler type or a fan? I eventually want to get one for my setup.
Old Jun 16, 2006 | 11:45 AM
  #62
roneski's Avatar
Devil's Advocate
Here's my oil cooler thread. The tranny and power steering coolers seem to be working fine but the oil cooler doesn't seem to be getting the job done. I'm probably going to relocate it this weekend and see what happens.
https://g35driver.com/forums/showthr...ght=oil+cooler
Old Jun 16, 2006 | 12:24 PM
  #63
Xman's Avatar
Thanks Roneski. I need to take a look at the spacing. I think it should work.
Old Jun 29, 2006 | 06:18 PM
  #64
G-Mony's Avatar
Noticed you had SGP VB upgrade done. how is it? I heard it shifts pretty hard.
Looking at the posts on my350z nobody liking the Stillen VB. Most of those guys are looking for over 450whp and want to chirp their wheels in 1-3 gears. This'll be my daily driver and was gonna do a conservative tune 6-7.5psi...so thinkin the Stillen VB might work. and i dont think you can redo your VB after you've upgraded...so gotta get it right the first time.
Old Jun 29, 2006 | 07:02 PM
  #65
roneski's Avatar
Devil's Advocate
I got the Forged Internals version of the VB and it's way aggressive. Nice at the track, but honestly it kind of ruins it for around the town driving. It definitely chirps second and third though, even on drag radials.
Old Jun 30, 2006 | 12:57 AM
  #66
Dsskyline's Avatar
What did you run at the track? Does the FI VB shift hard even in auto mode just crusing around? I have the stillen vb you can't tell it's upgraded unless get on it in auto mode, but you can definately tell in manual mode though.
Old Jun 30, 2006 | 01:58 AM
  #67
roneski's Avatar
Devil's Advocate
I'm only running mid 13s at the drag strip but that's mostly because of not being to get traction because of all of the negative camber that I'm running. My car is really set up for road courses.
In full auto mode it still shifts hard but it's tolerable if you keep the RPMs low.
Old Jul 1, 2006 | 02:54 AM
  #68
G-Mony's Avatar
sounds like its pretty similiar to SGPs VB upgrade
do you even think VB upgrade is necessary... if i'm running a conservative map? sounds like you were pretty happy w/ the initial install...
Shifting is smooth as silk, no different from stock. Ride is awesome, idles great.
400whp sounds nice but i'll be happy w/ 360whp
Old Jul 27, 2006 | 10:27 AM
  #69
roneski's Avatar
Devil's Advocate
Sorry for the late response. I was extremely happy with the initial result. I may be looking to swich out my VB with someone that wants the upgrade. There is something to be said for chirping second and third, but I don't drag race enough to really enjoy it. At stock boost I'm making 360whp and that's plenty for the street. To be honest I can't really feel much difference between 6 pounds of boost and 9 pounds.
Old Jul 27, 2006 | 12:36 PM
  #70
rookie's Avatar
I have the same VB, it's pretty mellow in auto mode for me. The shifts get aggressive as I get aggressive with the throttle. Did you do a TC?
Old Jul 27, 2006 | 12:38 PM
  #71
roneski's Avatar
Devil's Advocate
Didn't do a TC. I was scared that it might make it shift even harder. I had one of the first upgraded VB units from Sharif. I suspect that he may have toned down the aggressiveness a bit.
Old Jul 27, 2006 | 12:54 PM
  #72
rookie's Avatar
That may be true, if you're ever back down at VRT let me know I can swing down and let you feel the Edge TC. It rides pretty smooth in auto, I can chirp 2nd and somtimes 3rd when I get aggressive.
Old Jul 27, 2006 | 01:22 PM
  #73
roneski's Avatar
Devil's Advocate
Was the Edge Racing converter a whole new unit, or did they modify yours? I've been waiting for someone to come up with a complete aftermarket unit so that I can swap my stock one back in in case I don't like it.
Old Jul 27, 2006 | 01:29 PM
  #74
rookie's Avatar
I originally had a L10 no core needed TC, but it started to make a humming type noise after some hard lanuches. Happy I was able to keep my core.
Talked to Andre at Edge again, (who I had already started to talk to in case L10 didn't come thru) about the noise and around town driveability and from that he got what he needed to mod mine. Turn around was 2-3 days and it was down at VRT waiting for me. Edge has done a few RE5R05A converters and knows their are several different specs for the TC and stall speeds.
I have since launched it hard with no humming noises as a result, so it's holding up to some punishment. Again, if you're in town or if I'm out your way I'd be happy to let take it for a spin.
Old Jul 27, 2006 | 02:09 PM
  #75
RockG's Avatar
Roneski, what kind of gas mileage are you getting with the JWT TT (with your set-up)?
