stillen stage 4
Old Apr 5, 2006 | 11:36 AM
Texasscout's Avatar
Thanks for the info! However, only stage 1 and 2 have the warranty correct?
Old Apr 5, 2006 | 12:33 PM
nate4598's Avatar
Only stage 2 have warranty
Old Apr 6, 2006 | 04:24 PM
nate4598's Avatar
does anyone in here with stage 4 getting over 9psi ?
Old Apr 6, 2006 | 05:51 PM
Skyline_G35's Avatar
English dude, English
Nate, I sent you a PM.
Old Apr 6, 2006 | 06:29 PM
nate4598's Avatar
didn't recieve any
Old Apr 7, 2006 | 04:27 AM
nate4598's Avatar
I just went & test drove the car....awesome pull ...powerband is all the way til 6.5~7K rpm.... very very happy with the kit. I think I was little above 9psi on my boost gauge
Old Apr 7, 2006 | 01:23 PM
tomcatm's Avatar
What the most typical wheel hp/tq seen with a stage 2? Also are there any other hoods, other than the stillen hood you can use with the stage 2.
Old Apr 10, 2006 | 05:35 PM
nate4598's Avatar
for AT....mine was 283 whp/ 280tq with stage2...and no other hood, not that I know of
Old Apr 10, 2006 | 07:41 PM
tomcatm's Avatar
Ok this is prolly a very dumb question....buts whats to stop somone from changing out the pulley to stage 3 on the stage 2 setup and then putting back the stage 2 pulley if something went wrong and they wanted to claim warranty work.
Old Apr 10, 2006 | 08:17 PM
Cersoft's Avatar
Nothing .... except from burning guilt ....
Old Apr 10, 2006 | 08:49 PM
Did you see the 350z run 12.9 in the 1/4 with a KnN, plenum spacer, test pipes, slicks, and a utec? And us guys are running that with a SC. What the deal? If we added the Utec, do you think that would help us even more? Any of us using slicks? We need answers people.
Old Apr 10, 2006 | 08:55 PM
bfan13's Avatar
Adding the Utec would allow us to tune the engine and thus generate more power because our setup now is running so rich. in order to do so, i think we would need to get a bigger fuel pump and larger injectors, that way we can elimate the use of the 7th injector
Old Apr 10, 2006 | 09:04 PM
Man bfan13, you need to post more. You have been on these boards as long as I have and you have less than 50 posts? Do you spend more time at a different site?
By the way you need to post your info in the sticky at the top of the section. Thanks.
Old Apr 10, 2006 | 09:58 PM
codeflux's Avatar
don't worry about 350z folks. keep in mind, that on slicks you can get better times, and that 350z is quite a bit lighter than G35.
as far as lean conditions go on stage 3, this can be cured with a fuel pump upgrade. sukhi, whose stage 3 stillen i am buying, had to upgrade to Walbro 190 pump, because he was running too lean.
i will definitely be putting more research into stage 4 before i jump on that, but the numbers look impressive - almost as impressive as the absolutely linear torque curve.
Old Apr 11, 2006 | 01:58 AM
  #30
nate4598's Avatar
I was told by Ted @ Scott Performance that Nissan/Stillen can pull the history of the ECU or piggback to look for the level of boost...hmm but again no one can verify if this is true or not
