G35 & G37, Coupes & Sedans
Oil & Filter Change
Old Jun 7, 2006 | 12:43 PM
FenixL1P's Avatar
Originally Posted by dTor
If you think this oil filter is small, you should see the one for my Scion xB. It is so small, I thought it was for a riding mower!
but the vq35 motor is 3.5 liter v6 where as the scion xb has like less than a 1.6liter motor, correct me if i'm wrong...
my old man's 280z has a oil filter the size of a 32 ounce gatorade bottle and that's a 2.8 liter motor...
but i was indeed surprised the first time i changed the oil on my 2k2 6spd maxima that the vq35 had such a small filter....
Old Jun 7, 2006 | 12:50 PM
FenixL1P's Avatar
Originally Posted by DHCrocks
I'm still on the gasket that came with the car after 8 changes. There's a hole in the underpan that you can access the filter from. It's a tight fit but it works, you don't need to take it off. Just stuff a rag in there to catch the oil that spills.
i've only changed my oil drain plug gasket on my 2k2 6spd maxima like once and that was like after the fifth oil change..... been on the same gasket since and i'm already at about the 20th oil change... not a nary a drip at the plug.....
as for the g, i will probably get a new gasket every 2 oil changes.... unless infiniti service changes for me...i'll ask if they do the next time since i forgot about it during a recent oil change at infiniti...
Old Jun 7, 2006 | 12:55 PM
waterp7's Avatar
On the oil dipstick, where should the oil level be at? I just checked my oil after driving about 3k miles on my first synthetic oil swap (car has 16k). My oil level is a little above half way to full according to the markers. Is that adequate or should i add more oil?
I have a feeling my car might be burning a little oil.
Old Jun 8, 2006 | 03:45 AM
Grumpy_G's Avatar
In the middle is where you want to be, the happy medium. Now if you were going on a road trip, I would nudge it up toward the full mark for good measure. Check the level at every full tank of gas, a good habit to get into. I always keep an extra quart in the trunk for emergency.
Old Jun 8, 2006 | 06:34 AM
Fassster10's Avatar
Question guys? do you guys change the oil yourselves because it saves you a few bucks or because this way you are sure you didnt get fooled by a shop of charging you and not doing the oil change? i usually just take the oil and filter and plug to the shop and watch them do it in front of me, i think its too much of a hassle to change the oil especially considering on how low the G is...
Old Jun 8, 2006 | 01:33 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
Originally Posted by Q451990
Speaking of oil changes... is anyone else amazed at how small the oil filters on this car? Looks like something that goes on a motorcycle! I bought the secondary part number filter that is a little longer, but it's still thimble sized.
Heath
What's really sad is that's the same size filter almost every 04 and up Nissan/Infiniti uses... even my dads 5.6L Titan...
-GP-
Old Jun 8, 2006 | 02:06 PM
waterp7's Avatar
the 5.6L V8 uses the same filter??? maybe they really trust their engines not to F#(K up...lol...thus needing a bigger filter
Old Jun 15, 2006 | 07:08 AM
Bobalude's Avatar
I just changed my oil for the third time in 6400 miles last night. Having a cordless drill with a 10mm socket makes this job super easy. I put mine up on jack stands with hockey puck buffers and a floor jack. Rotated the tires at the same time.
is there any chance you can post some pictures of the hockey puck buffers/adapters you made for the jack stands? I am curious to see an example of it to help with making my own.
derres
Aug 28, 2015 03:27 PM
JoeMac
Aug 20, 2015 10:17 AM
linedr89
Aug 17, 2015 05:11 PM
ClwMike
Jul 23, 2015 12:55 PM
