G35 & G37, Coupes & Sedans
Do you have to buy new shocks if you replace the springs?
Old Jun 19, 2006 | 12:29 PM
Sooner97's Avatar
I ordered 4 Espelir springs to lower my car about 1 inch all around. I called a local Meineke shop to have them installed but the guy told me that I would need to buy shocks that are 1 inch lower if I wanted my car to drive properly. I was wondering if this is true and if others have only replaced the springs but kept the OEM shocks. Also, what's the usual labor cost to have 4 springs installed? Thanks.
Old Jun 19, 2006 | 01:48 PM
ballisticus's Avatar
I have the Eibach prokit for a 1" drop with the stock non-sport shocks. The car handles fine. Could it be better with proper aftermarket shocks? Sure. Once the stockers start to leak, I will replace them. The stock shocks are now under continuous compression ouside their normal static point, so they will not last long like that. Give them a year at best.
Old Jun 19, 2006 | 02:31 PM
FenixL1P's Avatar
don't forget to include an alignment job after the spring (or spring & shock) install cause alignment will be affected....
Old Jun 19, 2006 | 06:08 PM
Sooner97's Avatar
Thanks for the info. I did call around some more and I forgot that the Espelir springs only drop the car about 0.5 inch so it should be fine to use the OEM shocks.
rezendvous420
May 31, 2020 01:26 PM
itschuckster
Jul 25, 2015 08:07 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
cyrus32
Jul 18, 2015 06:22 PM
